Results 1 to 3 of 3
    Mar 15 2008
    buffalo
    Starting troubles
    Hey all, i just bought my first Audi a month or so ago and everything has better wonderful. Until last night when i got out of work, when i turned the ignition it was very hesitant to turn over,but after a few seconds it did. Didn't think much of it, drove home and went to bed. Wake up this morning and the same thing, drive around the block, turn the engine off and then back on and it started up perfectly. I was home most of the day so every few hours i went and took the car for a spin to see if anything changed. Same result: after the car sits a few hours, very hesitant start, once started 1x turns over perfect after that. My car is a 02 A4 3.0 with 48k
    Any thoughts?
    Thanks
    Veteran Member Three Rings AudiMat's Avatar
    Feb 22 2004
    Chicago, IL
    Re: Starting troubles
    I'm having this exact same problem, except last night the car just flat out would not start after leaving it with the flashers and parking lights on for 10 min. I am assuming its the Battery so I went out and bought a new one but didnt realize there is a bolt that I needed to get out under the strut brace to get the bettery out. I stopped trying to deal with it at 10pm and will go back to it this afternoon after work and see if I can get the battery in and that was the problem or not.
    -Matt
    Current:2018 A4 Prestige / Gotland Gang
    Past: Ibis White '12 S4 Prestige, Laser Blue '09 VW GLI, Black '06 S4, Cactus Green '01 S4, Black '02 3.slow, Santorin Blue '01 1.8T (and a bunch of Saabs and Subarus also in there that are not worth mentioning)
    Mar 15 2008
    buffalo
    i dunno if we have the same problem, yours sounds like a battery issue, my car has a very strong start, the engine just wont turn over easily
