Results 1 to 9 of 9
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    How does my timing look? 16712 P0328 Content
    I've been getting this code "16712 P0328 Knock Sensor (KS) 1 -G61: High Input (sporadic)" randomly. Got it 2 weeks ago, cleared it and it came back yesterday. I feel like the car holds back when I down shift even tho its boosting like normal @16 psi (APR software on K03s).
    KS 1, G61 is the Knock Sensor w/ green wire detecting knock on cyl 3 and 4. Does this code signify knocking or is the sensor malfunctioning?
    I got 2 logs of WOT 2nd to 5th gear of block 3 and 20. CF looks to be in speck, but is normally higher when just cruising or taking off from a dead stop which I find weird.
    Block 3 and 20 Log
    Any tips are appreciated.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: How does my timing look? 16712 P0328 Content
    Afternoon Bump
    You can definitely see timing retard on cyl 3 and 4 due to this code I have, but then CF goes to zero and it pulls just fine in upper gears. Temperature outside was roughly 79 and I'm on the stock side mount.
    93 Octane V-Power Gas
    Oct 02 2007
    toronto
    Your timing looks very different between different cylinders - is this normal? High retard on 3-4 and less on 1-2.
    Another suggestion, can you log less things (take out MAF and ignition angle) and then turn up the time interval to get more data? I've only logged two-three times so I might be talking nonsense. Free bump until someone smart gets here at least.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    The difference between cyl 1&2 and 3&4 is because of that code stated above. It is got G61 sensor, which is the knock sensor for cyl 3&4.
    Is it knock its hearing or is it malfunctioning? I'm byuing a new sensor this week. No place stocks them.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Have you tried logging the knock sensor voltage?
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I can only log up to Block 25
    Whick block is it anyway?
    Jul 07 2004
    socal
    It might be 24.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I bought a new Knock Sensor G61 (Green Plug). I'm willing to attempt this but I can't even see the sensor on the motor so this could turn ugly.
    This is the sensor on cyl 3 & 4 (according to bentley).
    Anyone have tips for getting to it? 2001.5 AWM
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    to get to the knock sensors you will probably have to remove the intake manifold. Our cars have 2 knock sensors one between cylinders 1 and 2, then one is between 3 and 4.
    and your timing looks under control, nothing to be alarmed about. I would do what mike suggests log the knock sensor voltages. this will give you an idea on what they are seeing, and give you an idea if it is working correctly
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
