Thread: Clutch
    Jan 28 2008
    Chicago
    Clutch
    Ok first of all, I feel like the friction point of my clutch is high; it might be because of different shoes, but for some reason it does feel higher than normal.
    This happens like once every 150 times:
    I'm stopped and in first (engine is warm), and I start bringing the clutch out and accelerating (normal routine) but the clutch is all the way out and the RPMs are climbing but I'm going nowhere; sort of like a new driver reving it real high and bringing the clutch out slowly. Obviously it's slipping right?
    (Also, I don't know if this is just in my head or what, but it seems like when this happens the clutch feels softer (less resistance), and gets stuck at around the g spot.)
    So as soon as I realize that, I switch into 2nd, and it does it again, then 3rd - and mind you, I'm going like 10 MPH - it seems fine. From that point on it drives without the slipping (but maybe, like I stated above, friction point is high).
    Cliffnotes: With the engine warm, in first the clutch slips, same with in second, but then after I switch into third, it feels fine from then on - even first and second.
    I do have check engine light on (if you read my other post) and I am taking it to the Audi asap.
    What do you think is wrong? Or is it all in between my ears.
    Nov 04 2006
    05 S4
    LI, NY
    Re: Clutch
    sounds like your clutch is slipping or the pressure plate is weakining. either that or you should get some used shoes
    Oetty roof spolier // FI Catback // Ecodes // Xenon Interiors // Solaris and LED Exteriors // Lower Euro-grille // ECS Snub // PSS9s // 19x8.5 BBS CH on 245 Potenzas // Euro RS4 Exclusive shift knob and Pedal Set // Carbon Fiber Trim // Custom Carbon Fiber Emblems
    Originally Posted by Justincredible
    "With the flux mod you can just put the supercharger in the trunk for extra traction"
    Registered Member Two Rings
    Oct 21 2006
    '07 Audi RS4; '98 240SX Turbo
    In the O.C., baby
    Re: Clutch
    Quote Originally Posted by S4QuattroB6 View Post
    Assuming the hydraulic system is working properly, CLutch slipping = wasted clutch, plain and simple. It's on it's last legs. Bring it in for a change before it leaves you stranded.
    Living my dreams...
    Jan 28 2008
    Chicago
    Re: Clutch
    Thanks, how much does a new clutch run for for these cars?
    And another thing I realized, I was in 2nd gear accelerating slowly (parking lot), and at around 2k or 3k RPMs, it stops for a slight second as if I took my foot off the accelerator and then engaged again. Anything wrong here? I do have Check Engine light on, but I don't think I damaged anything as the car is runnign fine besides these 2 problems (one being the clutch, other being ???)
    Thanks again guys.
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Re: Clutch
    I've had a problem and ordered Sachs Racing Organic Clutch kit...
    The disc, along with the plate
    Check
    http://www.audizine.com/forum/showthread.php?t=216719
    Audi A4 in an RS4 body
    Mike
