Results 1 to 8 of 8
Thread: Tire size
    Nov 26 2007
    Tire size
    What size tires should I run on 18by8 and 18 by 9 wheels?
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Tire size
    What's the car ?
    Nov 26 2007
    Re: Tire size
    06 A4 quattro and how wide can I go with the tires for the front and rear.
    Oct 06 2006
    South Bend, IN
    Re: Tire size
    Can't make recommendations for staggered fitments, but 245/40R18 is as wide as we recommend all the way around.
    Nov 26 2007
    Re: Tire size
    Thanks Doc I know I am walking on thin ice here but even though the rear is 9 inches could I run the size you mentioned all around?
    Veteran Member Three Rings CaptDistraction's Avatar
    May 20 2008
    Scottsdale, Az
    Re: Tire size
    245 width works pretty well on both those sizes. At least it did for mustangs.
    Jun 14 2005
    Anaheim, CA
    Re: Tire size
    Quote Originally Posted by 2871mds View Post
    9" wheel will be fine for a 245.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Oct 06 2006
    South Bend, IN
    Re: Tire size
    That size has a rim width range from 8" to 9.5", so should be no problem.
