Originally Posted by
akaEsCo01
You don't need them....For the rear, support the drivetrain with a jack, take out the subframe bolts and slowly lower the subframe. The springs will almost literally fall out depending on how low you go, if not then push down on the hub and they will fall out. This way tackles both sides at once, if you are not comfortable with that then take out only the 2 subframe bolts on the side you are working on, lower it, take the springs out (may need to push the hub down) and put it back together, then move to the other side and repeat.
Something folks should know, with this method...
By the Factory Repair Manual(AKA Bentley), the rear sub-frame bolts are of "one-time-use" or also known as "stretch-bolts". The manual states to replace them if they have been loosened.
Also you run the risk of altering the rear sub-frame alignment, removing all 4 bolts at the same time.
People have R&R'd the rear springs without removing the subframe bolts.
All it takes is the proper technique and the correct spring compressors-
BTDT!
