I know they are more expensive than eBay ones but these are excellent:
http://www.hifisoundconnection.com/S...41248237246241
They are installer quality and work a helluva lot better than cheap eBay ones. Of course if you don't see yourself pulling the radio more than once I guess you could get the cheap ones....of course that's what I thought and have probably pulled it 5 times including replacing it with a SymII+
As for tutorials, just push the key in with the flat side facing out and it will click letting you know it has engaged the lock. Then you pull lightly on the 2 on one side then the other, it will wiggle out. Of course this is better with 2 people as you can slowly pull on both sides. make sure you put down a towel so you don't accidentally scratch your shifter or trim.
Tip: If you have a Symphony I (with a tape player) you can stick your hand in the tape deck and pull from there once the keys are in.
