Results 1 to 7 of 7
    Apr 07 2008
    Little Tikes Hummer for my son
    Montréal
    2008 A4 AC Black car question
    Hello, I have a Black 2008 A4 3.2 and would like you feed back on the AC control. On a hot day (28/29) I set it up to 19.5 and it feels 22. If it is at 22 it is like 25.
    It is my fist black car so maybe it is normal because of the color that it needs to be lower then usual?
    I bought the car in US and imported it to Canada maybe it remember that are currency was low for a long time and it is the conversion effect
    Or maybe there is somthing wrong with it.
    Somewone have the same experience?
    Veteran Member Three Rings A4 JooN 2.0T's Avatar
    Sep 24 2007
    |07 B7 A4 2.0t Qtip|
    nyc
    Re: 2008 A4 AC Black car question
    Quote Originally Posted by Snowman View Post
    do you have any aftermarket pulleys??
    2007 B7 A4 2.0t Qtip Brilliant Black on Black -=- Revo Stg 2/SPS2 -=- Milltek Catback Labree Quads -=- Eurocode Testpipe -=- K&N Filter -=- Forge DV -=-RS4 Rear Sway -=- ECS Quick Spool Pulley -=- Neuspeed SS -=- 20% 3M Tint -=- Lamin-X Yellow Fogs -=- LED UV Blacklight Interior Lights -=-O.Z Ultraleggera Black w/ Yokohama S.Drives
    Apr 07 2008
    Montréal
    Quote Originally Posted by A4 JooN 2.0T View Post
    Nope. All stock. No gargage tuched it scince I owne it and I only opened the hood to check oil and windshield washer. But, thanks for the try.
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    I personally think the audi A/C is lackluster. It's not horrible, but compared to my acura and a few other cars I've driven, it's not as good. I have a black on black car, so that doesn't help. Also being in Houston where it's so damn hot doesn't either. And the V8 in the S4 produces a lot of heat...I can feel it at my feet through the firewall sometimes.
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Yup, the AC on the black A4s is overwhelmed by the extra heat the car accumulates.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Active Member Four Rings 3.2some's Avatar
    Dec 19 2007
    ..is full of crap I dont need
    Escondido, CA
    Quote Originally Posted by HID View Post
    That plus brilliant black is the HOTNESS so it has to compensate for that too....
    V/R -Phil
    B7 2006 Audi A4 3.2L Tip FWD Brilliant Black
    Apr 07 2008
    Montréal
    Thanks to confirm my toughts.
