Results 1 to 23 of 23
    May 22 2008
    Santa Maria
    SD Card problems
    seems no matter what I do, my navi says the card has corrupted data on it. anyone got any ideas?
    Veteran Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Re: SD Card problems
    Quote Originally Posted by Hartge330Ci View Post
    How did you format your SD card?
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
    Veteran Member Four Rings Vito Roma's Avatar
    Oct 08 2007
    Syracuse, NY
    porn?
    '12 Bril. Black A4 2.0T/Quattro/Prem+/Sports package
    SLine body/Sline Door sills/3 spoke pref wheel w.Paddles/Sport seats/VMR 708 Matte Black(19x8.5) **For Sale**/Custom Black OEM caps/35% Tint/Needle Swipe/Fob/"Wink" & Amber Delete/More VagCom/RS4 Grille/ Hoen Endurance Fogs/ST Coilovers *Sold* /Debadged/V1 w. Concealed display *Sold*
    Mar 27 2008
    06 A4 2.0T Q MT, Jeep GC
    PA
    what size is your card?? i read somewhere that the max size you can use is 2gig... i know my laptops card reader did funnythings when i put a 2 gig cad in it as it was made to read a max of 1 gig...
    Veteran Member Two Rings KMHPaladin's Avatar
    Dec 12 2004
    North Jersey
    You cannot use an SDHC card in an RNS-E. In other words, you are limited to 4gb.
    Current: 2016 S3 Sepang Blue | 2006 Lotus Exige Storm Titanium
    Previous : 2006 A4 2.0tqm Quartz Gray | 1997 A4 2.8qm Europa Blue
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    That was my mistake too... I originally ordered an 8GB card, but had to exchange it for two 4GB cards. I ordered the Transcend brand and they work perfectly. Didn't even have to format as they already came pre-formatted.
    Established Member Two Rings Robninja's Avatar
    Feb 15 2008
    North Tustin, CA
    I use the 4GB non-SDHC Transcend cards(from newegg.com) as well. Works great!
    Veteran Member Three Rings felondnb's Avatar
    Jan 12 2008
    London, UK
    Quote Originally Posted by Robninja View Post
    Yup - i'm using the same 4Gb standard SD from Transcend. I got mine via eBay for £15 - bargain.
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    May 22 2008
    Santa Maria
    I formatted it usinf windows. I think it was FAT 32.
    May 21 2008
    Quote Originally Posted by felondnb View Post
    you got ripped off... I paid $18
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    It's weird, whenever I use my laptop's built-in SD card reader to transfer data (Using Vista Ultimate 64-bit) I always end up with corrupted data.
    Then I switch over to my desktop (XP, 32-bit) using a SD card reader- it's fine lol.
    Damn you Vista!
    2006 Audi A4 2.0T Quattro 6MT S-line
    May 21 2008
    Vista blows. I use XP 64 bit. Best OS for PC.
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    I thought standard SD cards only go up to 2GB and anything above that is SDHC?
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    May 21 2008
    Although there some 4GB SDHC cards, you can get regular 4GB SD's too. 8GB is HC only
    Jul 02 2008
    Pasadena
    I bought a 4gig SDHC by SanDisk and everytime I put it into the card, it says loading. After a good 15-20 min. it shows empty.
    Am I doing something wrong? Is it my SD?
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    Quote Originally Posted by RLM View Post
    SDHC is the problem. Not compatible.
    Sep 17 2006
    Houston, TX
    That's the correct way to do it. Try a different computer/reader if possible. Some cheap ones really are crap. Vista/XP shouldn't matter as I've personally used both.
    Jul 02 2008
    Pasadena
    K, So I changed the SD card so its not a SDHC and it works....but it only shows half of the folders that I put on, and some folders are missing songs...anyone have an idea of what the problem may be?
    May 21 2008
    Are the filenames of the songs not showing up longer than 64 characters? If so, try renaming the files to no more than 64 characters and see if they show up. Here's a link to a simple program I found that analyzes the length of the filenames: http://www.optimumx.com/download/PathAnalyzer_Beta.zip
    To install it, you might need the Microsoft .NET Framework v2.0 (if you don't have it on your system): http://www.microsoft.com/downloads/d...d-aab15c5e04f5
    Also, there are few characters such as "!" that will meke the mp3 file unreadable to the Audi RNS-E.
    Jan 12 2008
    London, UK
    Quote Originally Posted by ibiski View Post
    lol - everything is cheaper is the US
    Sep 17 2006
    Houston, TX
    Also, there is a limit to the number of files. I run in to that problem if I'm not paying attention. I think it's something around 256? Maybe it's 512? I can't remember.
    Established Member Two Rings bigredx24x's Avatar
    Sep 23 2008
    06 25quattro s4, 95 Ford Rgr, 05 sv650
    DC
    For those of you that use the 4gb SD cards, which SD-card reader do you use for your computer? Because my current SD-card reader will not read anything 2gb and above.
    Thanks.
    Sep 23 2008
    DC
    Quote Originally Posted by enigma1406 View Post
    According to the following post, the limit is 400 songs:
    http://www.audizine.com/forum/showpo...26&postcount=3
