Results 1 to 10 of 10
    Sep 11 2007
    Baton Rouge
    Searched, Searched, and no help..
    So i kind of blew my front speakers, not to the point of bad music but just to the point of harsh crackling highs so i just decided i would throw my 6.5 Alpine R components in that I had in my old car..
    First problem is, i think they will be underpowered but i dont mind for the moment because i will be upgrading everything later and can run an amp to them.
    Second problem is... HOW do you take off everything on your doors to get to the speakers?! I had these speakers in a WRX which was 2 bolts and a bunch of pins so now i look at these doors just completely confused.. any help would be great because i would like to start tuesday.
    Thank you everyone.
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Re: Searched, Searched, and no help..
    What HU are you running? Stock, aftermarket? Bose? Give us something to work w/here.
    Sep 11 2007
    Baton Rouge
    i have the stock non bose stereo but all i need to know is how to take the door panels off to change the speakers.. any links to that?
    Dec 01 2007
    San Jose CA
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    wow, that's a great writeup. I have never had a need to search for it but I'll be bookmarking it. Nice!
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Sep 11 2007
    Baton Rouge
    thank you so much!
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Will upgrading the speakers and keeping the stock HU make a big improvement? I was thinking about doing the same thing.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Dec 01 2007
    San Jose CA
    I was debating the same and swapped in a new HU. I'm very happy with the results. Added bonus... now I'm running a sub again which I never got around to doing in the B5. Loving that.
    http://forums.audiworld.com/a4gen2/msgs/1079572.phtml
    Active Member Two Rings rizvfe00's Avatar
    Mar 01 2008
    Pittsburgh,PA
    Burtonnboarda:
    The old school type R components are very power hungry. I hope they sound decent off that factory HU. Be careful that you don't turn it up too loud to compensate because I am assuming the rear speakers are still stock. You may not be able to hear the distortion over your front speakers.
    kwimberly:
    No, upgrading the stock speakers and keeping the same non-bose HU will not improve sound much if at all, unless your factory speakers are blown. In fact, it may actually sound like you are lacking mid-bass with peaky highs from the lack of power. It won't hurt anything of course, underpowering speakers causing them to blow is a myth. If you want an actual improvement you would have to either amp the aftermarket speakers keeping the factory HU using line output converters or buy an aftermarket HU then optionally add an amp. I haven't heard the non-bose a4 speakers but, normally a factory setup sounds better than cheap replacement speakers thrown in there because the factory speakers are designed to work in the air space of the doors and the exact wattage the stock HU provides. Thus, the conclusion is if the speakers are not blown and your not ready to spend AT LEAST $150 for a decent component set with an HU or amp or both stick to the factory setup.
    Sep 11 2007
    Baton Rouge
    Rizvfe00: Thank you for reminding me how much it takes to power the type r's... its been over a year and I had completely forgot that when i ran them without an amp I blew out my rear speakers, in a wrx it was a cheap fix but not for an audi..
    But thanks everyone for the links it will be so helpful when im ready to do this, but for now i think im going to just save up and buy some a couple amps and some subs for the back and redo everything at once so theres power going to every part of the car.
