Results 1 to 32 of 32
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    Nearly Died Today
    so this is how the story begins..this friday was my high school prom, and i went to a town nearby on friday to pick up my tie that i reserved at a tux place. while im going there, my shitty pirelli p6's fishtail and i slam the whole left side of the car on a huge curb, throwing off my wheel balance and alignment and loosening my axle bolt (which i did not know)
    this is a picture after the little crash, im lucky there was no body damage
    so after prom, my whole grade went straight down the shore to wildwood, which is 3 hours from here where we live. The car drove fine until the last 10 minutes. The car's ABS light came on, the speedometer stopped working and the rotor was making LOUD grinding sounds.
    when we got there i checked it out and the car looked like this
    so the axle bolt is missing which is very dangerous and can cause the wheel to fall right off. but me being my dumb confident cocky self thought it wouldnt hurt to drive 2 miles to a autozone to see if they might have a temporary bolt that would fit in to last the way home.
    literally 20 feet infront of the store on rt. 37...my wheel goes crooked and the car skids out (im lucky the wheel didnt fly off cuz then my car would be done)
    no pictures but the brake caliper is in half, the brake caliper carrier is in half, and the axle is off the track and i have two circle things with me that have many balls on them. oh and the rotor is still on the rim. what a great way to end prom weekend
    Veteran Member Four Rings dreamcar=rs4's Avatar
    Nov 04 2007
    A4 2.0T
    NorCal
    Re: Nearly Died Today
    holy sh!t dude thank god you're alright. I had my prom on may 17th but mostly everyone took limos. Were you driving aggressively when you were going to the tux place?
    Oct 29 2005
    10speed
    San Francisco, CA
    hey man if you need help let me know that sounds like a tough break.. Autozone would not have your axle bolt FYI
    - Clint
    Jun 29 2007
    Raleigh, NC
    WOW.... glad you're ok...
    not a good weekend for our cars apparently
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Senior Member Two Rings has6's Avatar
    Aug 06 2007
    '21 SQ5 | '20 XC40
    Brooklyn, NY
    yeah, thank god you have no body damage, that would've def. ruined your weekend
    Veteran Member Three Rings AWDTurboLuvr's Avatar
    Apr 21 2004
    A4
    Vancouver
    What...was it wet out??
    2003 A4 1.8T Quattro - [B5 S4 Brakes.SS lines.PBR pads] [SB OFE STG3 Clutch] [S4 RSB] [BBS CH 18"] [Falken 452] [CC MOD]
    2002 Mini Cooper S - RMW Tuned 191whp/168 lb-ft [Dinan S1] [JCW injectors] [JIC/Cross inverted coilovers] [TSW LCA] [Alta 15%] [GramLights Optomise57] [Dunlop Direzza Star Spec 215/45/17] [ProSport Boost Volt Gauge]
    Veteran Member Four Rings mioStile's Avatar
    Sep 25 2006
    Smile Re: Nearly Died Today
    Thank God you're alive man. When you think about it, maybe this prom weekend wasn't too shabby after all?
    Current Iggnshn: 2007 4.2L 6 speed quattro S4. Neuspeed catback. 20x8.5/20x9.5 BBS RSGT. PSS9. USC license plate. always my work in progress.[/FONT]
    AMA
    Together we can all defeat 2.0T and 2.7T crime
    Ya, I'm that guy...
    Senior Member Two Rings Shi-Fu JaY's Avatar
    Apr 06 2008
    Fontana, SoCal
    hummmm, theres gotta be more to the story than "my shitty pirelli p6's fishtail"
    my stock 16" with nearly bald, about 3 or 4/32nd thread bridgestone didnt even fail me in the rain, when I TRIED to catch em loose and slide....but nope nada damn thing happend, it just gripped
    Dec 06 2007
    ^^agreed! P6's aren't that bad, and my dad fell a sleep and sucked a curb with the same wheels and there was no damage except for the worst scratches i've ever seen! u had to of been going quick!
    -Kirk
    BetaAlphaTau Member #58
    Feb 17 2006
    So you fishtail, blame the tires, pretty much fark the whole side of the car, and then drive 3 hours just to make it to a prom.
    just got reminded why I don't come over here anymore.
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    yeah jeff i do blame the tires. i take that turn everyday in my car at the same speeds. my tires have hardely any grip. thanks alot guys for your concerns. im just so worried about what i should do about the car and how much its ganna cost. any idea for new/used calipers and carrier and maybe a new wheel bearing?
    Jan 16 2007
    Wetzlar
    usual answer from noob driver.
    You were driving too fast for conditions and stop blaming tires. I have the same half worn and never had problems.
    Dec 19 2007
    York, PA
    jeebus...glad youre okay. GL with the repairs
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    That is a very, very strange thing to happen from an impact. The axle bolts are installed with a LOT of torque, IIRC about 90 ft/lb plus another 90 degrees to stretch the bolt. I dont see how that could have loosened from an impact unless it sheared. Very strange.
    You should probably have the alignment checked to make sure the control arms were not tweaked. New bearing and bolt is ~$80, labor is expensive b/c you need to remove the upright. Calipers are cheap b/c people upgrade to the B5 S4 equipement and dump their stock components.
    If I were you, research how to perform the repairs (mostly available on the DIY here and on AW) and get wrenching. I hope you learned from this, those axle bolts are CRITICAL, imagine the torque that is exerted on the bearing while turning. Without that bolt... well, you know what happens.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Four Rings HeHateMe's Avatar
    Apr 05 2005
    lost wages, nv
    Quote Originally Posted by jeffahn View Post
    so You Fishtail, Blame The Tires, Pretty Much Fark The Whole Side Of The Car, And Then Drive 3 Hours Just To Make It To A Prom.
    Just Got Reminded Why I Don't Come Over Here Anymore.
    Lol
    <old school>
    --giacfxk03-siemensinjectors-milltekexhaust-ofestage4clutch-eibachprokit-stratmosphereshortshift--
    abracadabra homes http://www.audizine.com/gallery/data...une_06_142.jpg
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    normally prom problems come with the old mr.alcohol...Good thing you wernt drinkin because your reaction time would def not of been that fast...Glad to see ur olright
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    It probably worked itself loose during the 3 hour trip with all the bumps and such even if there was minimal turning.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    yeah man it worked itself out..trust me i work at a garage after school i know what im doing..anyone know where i can find "caliper carriers" from besides the dealership? i cant find any online at all. where did u find that bearing and bolt for 80 bucks? i cant seem to find anything cheap like that
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    best bet is to look at audi junkyards.. wen iwrecked my TT i found the whole rear assembly for my passenger rear suspension got it for about 200 bux! crazy cheap it was gonna cost 800 from audi... heres a number to call 877-643-7626... its a huge audi junkyard.. u hsould def be able to find it there... also dude there hasta be more to this story lol... u have traction control and esp man.... u hadda b goin wayyy tooo fast or sumtin.. i kno man i used to drive like an ass too ..til about last week wen i jus messed up my car... lol..good luck..and for the future..never drive that far when u screwed hit up that bad.. u coulda ended up doing way more $$$ in dammage
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Nov 25 2007
    02 audi a4 3.0
    ATL
    glad you're ok
    but remember speed kills.
    Apr 20 2007
    Lander, Wyoming
    Quote Originally Posted by trueno429 View Post
    www.autohausaz.com has parts for good prices, including that bearing kit.
    www.genuineaudiparts.com - email them for any weird part, they ahve great service
    Shokan is the all audi junkyard in NY. I've bought a few things from them in the past and have had good results. www.shokan.com or 1-800-all-audi is the phone number. They probably have a used caliper/carrier in stock.
    Jon
    go > show
    Ich liebe mein Audi
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    thanks alot guys for the help, i called shokan and they dont have any b6 parts in stock right now. and the 877 number i called wanted 50 bucks for the caliper/carrier. good deal right?
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    the garage wants 500 for labor and alignment..i need caliper, caliper carrier, hub and bearing assembly, a axle, and the axle bolt. good deal? i dont think so
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    You should know prices since you work there. That sounds like lots of work. I used to try and break traction on my P6 tires and had no luck. You must have hit sand. Thats some tough wheel you got there since it didn't get bent.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Glad you are OK!!!
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    thanks bro
    Established Member Two Rings drmarcj's Avatar
    Feb 14 2008
    xxxx
    Quote Originally Posted by JeffAhn View Post
    I liked this scenario better the first time I saw it, as a video they showed us in driver's ed. You know the one, where they show teenagers driving badly then getting killed on the best night of their lives? It's such a cliche I actually think he might be making this up.
    03 A4 Avant 1.8T -- 17" B7 RS4 reps | Sirius Satellite Retrofit | '02 Sport Susp.
    03 Lexus RX 300 -- Wife's car, no mods allowed
    98 Passat 18.T -- Sold
    92 Golf GL -- Long gone
    Registered Member Three Rings
    Aug 06 2007
    02 Audi A4 1.8T Q Tip
    New Jersey, USA
    First of all.... glad you're ok.
    sorry about the damage to the car....
    $50 for caliper/carrier is a GREAT deal (my opinion).
    There are a few of us in NJ that will be able to help you out with your repairs. Get the parts.... make the post.... we will come.
    Oh.... and make it a Saturday project and fire up the grill.... tell the folks you're having a few Audi friends over
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Just my two cents, but it really sounds like you're holding info back here... when I bought my car it had original skins on, with > 70,000 miles on them... and way out of alignment. I tried to get the car sideways... lots, and not much luck. Until winter... that is.
    Come on, you're among friends; give us the truth behind the story. It could save another AZ'er a similar fate...
    Anyways, so sorry to hear about your whip glad you're okay and all.
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Sep 03 2007
    park
    I have p6's and they suck ass. They squeel really early, and there bubbly and they look like sh*t too.
    But would never, EVER, lose control to the point of no fixable-ness on the street. Especially on a street i drive everyday.
    *thumbs down*
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    ok tactic, i forgot to add that it was raining. happy?
    Apr 20 2007
    Lander, Wyoming
    for crap's sake, he got a little loose in the rain and hit the curb. Safety nazis, attack!!
    I've done it before, especially when I had Nitto 555s on my wheels (came with them, I wouldnt have bought them). I've had the rear end step or front push out with S02's and 3's, Pilot sports, Dunlop Sport Maxx's... no tire is perfect in the rain. Im lucky I was never near a curb, but I've certainly drifted into the other lane a few times. Maybe I just drive too fast, but I've never crashed and have always had no problem pulling the car back with a little throttle and quattro assistance. Driving in the rain is what makes an Audi fun to drive, you have soooo much control when its on the limit, unlike rwd cars.
    He busted up his car, he needs advice on how to fix it, not advice on how to drive. I think its safe to assume he learned something about the handling of the car and tires, and that is enough said.
    Jon
    go > show
    Ich liebe mein Audi
