Results 1 to 15 of 15
    Apr 08 2008
    Toronto, Canada
    dipped headlights, vagcom needed
    I tried getting Vag-Com to work with Vista and it doesn't see my OBD interface cable, but sees a connection. Can anyone help me clear this error with their Vagcom?
    2002 Crystal Blue Metallic A4 1.8T Quattro
    2004 Black Volvo S60 2.5T AWD
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    Re: dipped headlights, vagcom needed
    Dipped headlight error can be "reset" by turning the car off then back on. However the error will come back if there is a problem with the headlight and can't be cleared unfortunately from what I have experienced myself.
    Mike
    Apr 08 2008
    Toronto, Canada
    Lights work, I just didn't tighten the connector to one of the lights when I disassembled the car and triggered the error by starting the car. Vag Com will clear it.
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by lorvar View Post
    I tried looking it up but it seems like you need some type of 2 channel adaptor according to a4mods.com. Do you have this? If so I have vag-com on my laptop
    Let me know if you need it and i'll charge my laptop. I'll be home all week
    Sep 24 2007
    Woodbridge, Ontario
    BTW, Have you tried d/c the battery.
    Apr 08 2008
    Toronto, Canada
    Still need to clear this code.
    Sep 24 2007
    Woodbridge, Ontario
    Have you disconnected the battery?
    Apr 08 2008
    Toronto, Canada
    Quote Originally Posted by audipotential View Post
    No, I'm afraid I'mm going to screw something up, we didn't try your cable, did we.
    Veteran Member Three Rings orangelmo's Avatar
    Jul 05 2007
    Stouffville
    Sorry to threadjack but... Is there anyone in Markham or close by with a B6 and has Xenons that will help me test mine out? I want to be certain that my ballasts are dead before putting an order for replacements
    Sep 24 2007
    Woodbridge, Ontario
    Just try disconnecting it its fine ive done it on mine a couple times
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Quote Originally Posted by orangelmo View Post
    How do you test it out? I might be able to help (but know nothing about cars)
    Is this fixed yet? I could try to get a laptop and use the a4mods.com method for that error.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Apr 08 2008
    Toronto, Canada
    Quote Originally Posted by WiZZLa View Post
    I have access to a laptop and software, but the article calls for a dual k line connector, do you have one of these? I just ordered one from ebay, but who knows when it'll show up. Where are you located?
    Jul 10 2007
    trunk
    Scarborough, not too far from Scarborough Town Centre. I have the KKL cable from eBay seller alpha-bid. I've only used it with 311.2 and 409.1.
    I think I'll be at audipotential's FMIC install in Dudebridge today for a bit around 1.
    Stage 0 minus - .5
    Apr 08 2008
    Toronto, Canada
    Thanks for the Vag today, WIZZla, much appreciated
    Jul 10 2007
    trunk
    np. Thanks for the clear corner.
    Stage 0 minus - .5
