Results 1 to 20 of 20
    Veteran Member Three Rings as4driver's Avatar
    Mar 28 2005
    2001 Audi s4, audi a4 avant
    Thick White Smoke???
    I Havent driven my car in about a week becuase i have some body work getting done. I decided to drive it today and after i let it warm up i proceed to get on the highway, i looked behind me and see thick white smoke covering the highway. The smell is like burning oil. The car holds boost but not full boost. When i got home i logged the car because the check engin light came on and found the following codes:
    Address 01: Engine Labels: 078-907-551-AZA.LBL
    Part No: 8D0 907 551 M
    Component: 2.7l V6/5VT G01 0002
    Coding: 06711
    Shop #: WSC 02325
    8 Faults Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    17968 - Maximum Engine Speed Exceeded: Engine Warranty VOID! :-)
    P1560 - 35-10 - - - Intermittent
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-10 - - - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 - -
    16688 - Cylinder 4: Misfire Detected
    P0304 - 35-00 - -
    16690 - Cylinder 6: Misfire Detected
    P0306 - 35-00 - -
    16689 - Cylinder 5: Misfire Detected
    P0305 - 35-00 - -
    16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
    P0154 - 35-00 - -
    Readiness: 0010 0000
    I STFA and discovered that it could be a blown turbo(I have Ko4s??), HG, N75, spider hose, and so on. Not really sure which is the problem. By the sound of it, i might concure that the problem is turbo related. Thanks in advance for the help. This is why i drive an Audi.
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    Re: Thick White Smoke???
    blown turbo most likely... check it out asap if you heard knocking....very bad chance ur engine might go as well.
    CT4952
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Wow,
    Yeah that doesnt sound like its good news for you. Do the turbo's make the loud dentist drill noise? You say you have K04's did you put them in or were they in when you bought the car.
    How hard have you driven it, I see the one code of maximum engine speed exceeded.
    Anyway. I hope the best for you and that its not anything serious, but man its not looking good from what you described.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Mar 28 2005
    I dont drive crazy but...LOL. The motor still idles fine and starts up with no problem.
    No they dont make the dentist drill sound like my ko3s did. The sound is different.
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    So it does make a non normal sound just different then the dentist drills?
    Well I wouldnt drive it until you find out what it is for sure. How many miles on the K04's
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    My thoughts are that something important to the engine is done onions.
    Mar 28 2005
    I wont drive it untill i know. Ther are only about 7000 miles on the ko4s. EPL Tuned
    Veteran Member Three Rings BlueturboS4's Avatar
    Feb 21 2006
    2010 s4, 2001 S4, 2002 dakota
    Looking to sell it by chance?
    Mar 28 2005
    I may consider after i get this problem straightened out.
    Feb 21 2006
    how about as is?
    Account Terminated Four Rings
    Jan 29 2008
    My Garage: My Garage:
    los angeles
    before my dad rebuilt my mr2, it was like this. he messed with the spark plugs i think made it run a little better. I was like 12 when this happened though so i'm not 100% sure.
    Jan 29 2008
    los angeles
    A bad spark plug can cause engine misfire, triggering the SERVICE ENGINE SOON or CHECK ENGINE light to appear.
    from : http://www.carcare.org/engine/spark_plug.shtml
    i might be talkin out of my ass though. I don't know anything about audi's.
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Looks like you have a ossible boost leak, thats the negative deviation.
    Your misfiring in 4,5, and 6 (same Head). thats bank 2. Possible POS/ICM failure. you have two. One for each bank right on top of the airbox.
    the low voltage is a low battery
    Lambda no acticity is a dead 02 sensors, looks like its the driver side, and its the 02 right after the turbo. Get is replaced. Its not like the rear 02 which dont need replacing right away.
    If you get white smoke once you let off the throttle, its possible Blown head gasket, If its during Acceleration you prob blew a seal in th turbo, Check your coolant tank and tel us what color the fluid is. Compression test
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    bye turbo
    SBSC
    I also like to live dangerously.
    Dec 06 2007
    Calgary, AB, Canada
    Do a pressure test. The white smoke could be a build up of condensation burning off.
    Watch your coolant level, and have a look to see if it looks clean or not. Also check to see if the oil looks like chocolate milk.
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    If i were to guess i would say its the turbo. But then again I could be way off.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by The_Jerbel View Post
    yeah i was going to say, maybe headgasket, that could be your issue. as Jordan said just go outside check your dipstick, or even easier look at your coolant.
    Dec 06 2007
    Calgary, AB, Canada
    Check both. It's possible when a HG blows for one fluid to contaminate the other, but not visa versa. Pop off the oil cap and have a look, as well as checking your coolant.
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    thats a blown turbo haha
    Jun 14 2007
    2000 S4
    Connecticut
    ^^ Haha
