Results 1 to 7 of 7
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Start up problem, searching didn't help.
    When the car has been off for hours, left over night etc.. (basically starting up when the engine is cold) it doesn't start up right. I turn the key, the rpms go up to about 200, then the car dies. however, second start up, it'll start up fine but the rpms will move up slowly.
    originally it would start up first try, but the rpms would hover around 100-400rpms before idling at 800. but now it won't even start up first try.. so it's getting worse in a short amount of time. so i don't think it's a vacuum problem
    MAF was replaced due to another problem
    any ideas? i'm about to head out to buy a new fuel filter, but i don't think thats the problem. maybe fuel pump?
    the outside temp doesn't matter, it happens at both 50 degrees and 90 degrees. my SAI still turns on at 90+ degrees which is odd, but I don't think it's related.
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Re: Start up problem, searching didn't help.
    Cam position sensor?
    Mine did that on its way out.
    ÖMGHI2Ü
    Photography
    Aug 29 2007
    Paktia, Afghanistan
    thanks for the reply.
    did yours throw a code on the way out?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    It is a longshot but a bad coolant temp sensor can cause some problems like that. The ecu doesn't know the car is cold and tries a hot start map which just won't work. The cam position sensor is a more likely bet though.
    Jim
    I Do Werk.
    Aug 29 2007
    Paktia, Afghanistan
    Alright, you guys are awesome. I'm not getting a cell though, I thought a cam position sensor would throw one?
    I'm about to head out now to work on my car.. I'm also getting a hissing noise and a very small leak on one of my hoses near the intake manifold. Going to remove my intake mani just to get to the hose and find a part number so I can replace it, I'll clean my throttle body while I'm at it..
    My coolant temp was replaced by me, just before they issued the warranty for it. So I'll shell out the cash for a cam position sensor and hope that it fixes the problem.. assuming the leaky/hissing hose isn't the issue.
    Thanks for the help guys.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Could the hissing hose be the L hose on the right of the intake manifold? My 2001 had a nasty tear in it and cause start up problems but i had rather crazy misfires and wouldn't stay on.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Aug 29 2007
    Paktia, Afghanistan
    I think the hissing noise might be coming from this, it's the only hose I could find that was obviously an issue.
    it's the hose with all the oil/crud on it.
    I'm about to make another post regarding that hose and a couple other things I have questions about.
