Results 1 to 16 of 16
    Established Member Two Rings Sp@cE418's Avatar
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    Going to drag for the first time ...
    Hi !
    I tried the search button but I don't have a constant answer ...
    First things first, here's my mods :
    Audi S4 2001.5 manual
    Giac 3- software
    Samco hoses
    K04
    RS4 Clutch
    AWE LWFW
    RS4 Engine mounts
    AWE S-Flo
    APR Bi-Pipe
    Piggie pipes
    Stock exhaust (still waiting for the 89mm from Autospeed)
    NO DTS
    NO Snub mount
    225/45/ZR17 Toyo Proxes T1R
    I just want to know how to lauch the car and the shifting points ...
    I read : Rev the car to 4000rpm and then it the gas pedal for the lauch and shift to the redline on all gears... Is that the right way ?
    What could I expect for a good time with 91 gas ?
    Are there "things not to do" for not breaking any parts and not being to hard for the transmission and the clutch ?
    Optimal pressure tire ?
    Thank you !
    Feb 17 2008
    Ottawa Ont.
    Re: Going to drag for the first time ...
    should be easy high 12s
    4k slip as opposed to a drop might work. I prefer a 5K drop myself but that RS4 clutch might not take that.
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    Quote Originally Posted by BastardS4 View Post
    Sorry for my ignorance but what is exactly the difference between slip and drop the clutch ?
    Registered Member Two Rings
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    Quote Originally Posted by Sp@cE418 View Post
    Slip- Let it out slow as your RPM's climb
    Drop- Let the clutch out like a "pop" as you put the gas to the floor
    GIAC Flashed ECU++++FORGE 007 DV's++++ECS 2 piece Front and Rear Rotors++++SS lines++++VOGTLAND GT's
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Don't do it, don't do it! You'll get addicted then you'll keep going back to the track until you burn your Rs4 clutch out, or break something else. Then you'll be banging your head, then fixing your car and spending oodles and oodles of money fixing it. Then you'll take it to the track again and repeat the process all over. Then you will contemplate selling it because its costing you so much money to fix. But you won't want to because you love the car and the power it produces. So you go round and round.....
    But it will be fun
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Quote Originally Posted by gointoscott View Post
    But it will be fun
    LOL!!!!!! and then you will be this guy.
    l gotta-- l gotta get
    a form from a scientist.
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    But it will be fun
    Ok thank you for your input ... so, basically, the best way to "minimise the risk" to break something is to slip or to drop ?
    BTW, I planned to do it just once ... I know I could't probably be able to contrain myself ... but anyway ... it's sure that I'll do it at least one time ...ahahahah
    Nov 12 2007
    Stamford, CT
    sorry, I guess I misunderstood the thread
    Senior Member Two Rings wackoo's Avatar
    San Francisco
    Drop it like its hot!!
    2001.5 Silver S4 JHM stage III
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    Quote Originally Posted by $4c@b View Post
    goddamnit!!! that was the first thing i was thinking about posting when i saw the thread title...you totally blew it..well heres my addition anyway.
    SBSC
    I also like to live dangerously.
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    Thanks ... really ... now with the pics I understand ...
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    I wanna die after looking at that. My soul is polluted.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    Why are you all laughing at me ?
    I made an effort to speak in english because it's not my first language (Is there something misunderstood ?) and i'm new to the world of sports cars ... What's wrong to try to learn ?
    Established Member Two Rings stevea6/z28's Avatar
    Jul 29 2007
    01a62.7t,2z28's,71exercisebike
    conn
    those pics on top some funny shit, nice
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    to minimize ur chance to break something, let the clutch out slowly as your rev the engine more. As called slipping the clutch. You still have some risk of breaking something, but i have seen some bad breakages when dumping the clutch.
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    Quote Originally Posted by haus4 View Post
    Thanks ...clear answer ...
