Results 1 to 38 of 38
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    Installed water/meth... Thoughts (long w/pics)
    so this week i went to install water/meth and switch software from apr 93 to apr 100 octane programming.
    i must say i love it, i highly recommend it to anyone whos looking for a little more. the car feels much smoother throughtout all of the RPM range and definantly alot more powerful. now i must say i believe that most of this is because if the apr 100, but the water meth allows for this so its all one big package. also, we did several logs on vag com during the dyno runs. everything apprears to be perfect, only time little problem is a slight timing pull in cyl #2 (not nearly enough to cause concern), but everything else was in order.
    Overall gains
    first run: 93 octane, no water meth, listed mods
    238 horsepower
    292 ft/lbs
    Intake temps: 39 C
    Second run: same as first
    242 horsepower
    298 ft/lbs
    Intake temps: 43 C
    third run: 100 octane with water meth
    249.9 horsepower
    320 ft/lbs
    intake temps: 37 C
    *note: with water meth u can expect around 37-39 C intake temps while without would be around 60 C (mine were low because car was cold on first pull)
    DYNO:
    PICS:
    WHAT WATER/METH?
    LINE TAPPED INTO THROTTLE BODY
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Re: Installed water/meth... Thoughts (long w/pics)
    Did you do the install? I'd be curious to know how that went. Nice increases!
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Sweet install! How much did you pay?
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    I saw it in person, and it looks great.
    That kit was installed in the same place I did mine. WolfCars.
    Ps.Spike is the man !!!
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    I'm still trying to understand the water/meth thing. Does the system mist with throttle input(all the time) or is like a nitrous system?
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Oct 14 2006
    MK6 Jetta
    South,FL
    It sprays in a pattern, and is activated after a predetermined amount of boost.
    On his is somewhere in between 13 and 15 psi.
    -EI AL CAI.
    -Driver Mod.
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Can this system be optimized for a stock car?
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Is there a reason you went for a rear tank instead of using the washer bottle which also gives you the low level warning in the dash?
    -Kris
    Veteran Member Three Rings johntesi's Avatar
    Jan 17 2008
    Evolution X
    Texas
    Looks awesome! Very stealth install.
    IceMole- maybe he wants to be able to clean his wipers still??
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    how safe is it to use constantly?
    Ih8OEM: i thought you were on a budget??? haha and now add this to your car
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by johntesi View Post
    ?? He can still do both running off the tank
    Veteran Member Three Rings A4RingPimp's Avatar
    May 24 2008
    DG '06 A4/ '08 Land Rover LR2
    On a peninsula
    I want this soooooooooooooooooooo BAD!!!!
    Veteran Member Four Rings Vito Roma's Avatar
    Oct 08 2007
    Syracuse, NY
    i want to do this my friend did it on his b6 how much was it?
    '12 Bril. Black A4 2.0T/Quattro/Prem+/Sports package
    SLine body/Sline Door sills/3 spoke pref wheel w.Paddles/Sport seats/VMR 708 Matte Black(19x8.5) **For Sale**/Custom Black OEM caps/35% Tint/Needle Swipe/Fob/"Wink" & Amber Delete/More VagCom/RS4 Grille/ Hoen Endurance Fogs/ST Coilovers *Sold* /Debadged/V1 w. Concealed display *Sold*
    Dec 27 2005
    New Orleans
    how was the tube ran from the trunk to the engine? I have a system and fat 0gauge already ran in the door sill..so I dont know if I can fit anything else under there.. did you ran it differently?
    Oct 09 2007
    E46 M3
    PA
    Quote Originally Posted by audipotential View Post
    exactly
    -Kris
    Feb 12 2004
    PA-NJ
    Wouldn't you be then squirting "boost juice" or whatever its called on your windows? I'd think a seperate tank is a better option.
    Aug 31 2007
    Miami
    okay lemme clear some things up... the system it self runs about $329. figure about 6 hours of labor. the reason i chose the rear tank instead of the washer fluid mount is because i wanted to stay away from tapping into any oem parts. incase i ever have to remove to sell the car, it would look completely flush as if nothing was ever tampered with (except the throttle body lol). as far as install goes, i did not install it but i was there watching my buddy spike at wolf do it. he basically ran the lines under the car. thru the wheel well. yeah hope that clears up most people
    IG | @fukn_fafa
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    any estimate on how long a full tank of the water/meth lasts? I'm assuming it only triggers on 3/4 trottle or on boost pressure?
    Aug 31 2007
    Miami
    Quote Originally Posted by vtracer20 View Post
    a full tank last about a tank of gas for me (I drive really hard) and its triggered @ 14 psi for me
    IG | @fukn_fafa
    Veteran Member Four Rings SilverB7FL's Avatar
    Feb 19 2007
    Built Twin Turbo 350Z
    S. Orlando
    wow i like that install nice and hidden. i should do this since i already have the apr 100 octane programming
    Girls love Audi too.
    Oct 09 2007
    E46 M3
    PA
    Quote Originally Posted by EuroA4 View Post
    What do you think washer fluid is? (hint: meth+water) RainX/blue stuff + 2x HEET or HEET + Distilled water in 50/50
    FYI: if anyone is going to use washer bottle DO NOT tap the bottle itself, run a T in the hose.
    -Kris
    Feb 19 2007
    S. Orlando
    thats it, this thread just convinced me to get it, expect to see another thread like this in a few weeks
    Jan 17 2008
    Evolution X
    Texas
    Duh! This isn't really my area of expertise as I don't like two tanks or having to refill something other than gas in order to maintain my power... I'm sure some of ya'll can relate to that. It really is a clean install and I should have remembered the wiper fluid deal from my evo forum lurking days.
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    dude nice job ! the set up is sick.
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Established Member Two Rings Eurotrash8's Avatar
    Apr 10 2008
    Calgary
    Where can you buy this? Is this a mod that can be do yourself? ie: how would you determine when it would inject and at what boost level?
    Oct 09 2007
    E46 M3
    PA
    USRT, depends on your setup (need to know for nozzle size), and you need to log log log
    -Kris
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    looks hot. i would like to see a 93 octane pull with the meth mist so we can distinguish how much increase you get from just the 100 octane and from just the meth.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Oct 09 2007
    E46 M3
    PA
    Quote Originally Posted by RedS-line View Post
    Unless you're pulling CF with 93 program it will only lower IAT and make A/F rich. The whole point behind meth is that you can increase timing/boost to make more power and keep IAT low.
    -Kris
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by IceMole View Post
    FYI... if you use the meth+water in your washer fluid bin and when you need it thrown onto your windows, it drips down to the ventilation system and if you don't have the inner circulation button pressed, you will be breathing in the methanol from the vents which is not good for you. Standard washer fluids no longer consists of methanol and contains more ethylene glycol, ethanol, water, and PAV. (thanks wikipedia) Rain-X Ice-X still uses pure methanol. But the standard blue is not methanol... Rain-X premium windshield washer fluid is <6% methanol, 90-95% water.
    what is the ratio for water/meth in water/meth systems?
    Oct 09 2007
    E46 M3
    PA
    "Boost Juice" is 49% Meth 51% water.
    I use 50/50 heet/distilled since I don't want to deal with the dye but have used RainX deicer+heet and blue+heet and yes you can buy blue with meth read the bottle that say "contains methanol" and good to -20F. The washer fluids are up to 40% meth and 58% water to which you add HEET that is ~99% meth.
    -Kris
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Any differences in fuel economy?
    Mar 19 2008
    interesting. i would like to know how many more points could one increase boost and timing with a device like a revo selectplus device with meth installed?
    2019 S5 BO.SS
    2009 R8 6 Volt :)
    Established Member Two Rings GEkido's Avatar
    Apr 25 2008
    Miami, FL
    I'm also curious about it running on empty. Do you have to constantly fill it or does it deactivate when the boost juice runs dry?
    2021 S5 Sportback | Glacier White | Sport Package | Black Optic | APR 93 Tune | APR FMIC | AWE CF Intake | 034 F.S.B. | 10/12.5mm Spacers
    Aug 31 2007
    Miami
    Quote Originally Posted by GEkido View Post
    no it does not deactivate. u have to keep an eye on it because it u run dry it will suck air thru the lines and thats bad. and as for me if im on 100 programming and i run dry on water, im not really sure but the reslts could be ugly
    IG | @fukn_fafa
    Veteran Member Four Rings turbo kraut's Avatar
    Oct 30 2006
    09 pontiac vibe
    StL, Missouri
    Quote Originally Posted by Eurotrash8 View Post
    if you are semi knowledgeable about diy projects this should be fairly easy, but there was a guy on af that did it and screwed his motor up
    see thread:
    http://www.audiforums.com/m_864314/tm.htm
    he installed a k04 on his a4, but had issues with this, so take head from his mistakes
    2001 Honda CBR929RR - modded - mine
    1992 Ford Bronco - The Beast - mine
    2009 Pontiac Vibe - stock - wifes
    1981 Suzuki GS1100 - sold
    2011 Ninja 650r - sold
    2001 Audi A4 - totaled 3/31/13
    2006 Honda CBR600RR - traded
    1982 Honda GL500 - sold
    2011 Ninja 250r - sold
    Apr 25 2008
    Miami, FL
    Wow, that guy on AF fu**ed up his car real bad!
    "When DIY goes wrong...
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Sure did F**k the car...Shame...
    Audi A4 in an RS4 body
    Mike
    Jan 21 2007
    "Old Yella"
    san antonio tx
    I'd like to see what this nozzle looks like? He said the screen on the nozzle came off becuse he installed it upside down? Huh? I don't see how something your supposed to install in the intake stream can come off that easily. Sounds like a cheap part that fail on the kit. Does anyone have a pic of what this nozzle looks like?
