Results 1 to 13 of 13
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    front crankshaft seal
    Who's ever had 1 leak? Mine seems to been leaking, replacing it seems like a bitch.
    Who's ever replaced one, how hard is taking of the timing gear thats pressed to the crankshaft?
    Dec 06 2007
    Calgary, AB, Canada
    Re: front crankshaft seal
    Not hard at all. Just use a gear puller...
    Feb 17 2004
    Sterling, VA
    The crank bolt has a 24mm 12point head. If you have the TDC pin screwed in, you should be able to crack it loose with some moderate force. Once the bolt is off, the crank sprocket should come right off. Just be careful not to crack the keyway in the sprocket or the crankshaft, that would be a mess for sure. When I bought all my timing parts last month, there was a sheet in the box explaining that many people have broken the key on the back of the sprocket...not sure how they are doing it. Maybe they didn't get the key seated before torquing it down?
    As for the seals, you can either rent/buy the crazy looking seal remover or there's the homemade version that I use:
    Take a small self tapping screw (1/8th inch) and drive it halfway into the seal's face. Then take a pair of vise grip pliers and lock them on the screw head. Pull the seal out. Takes a couple good tugs.
    Tap the new seal into place with a large diameter socket and a small hammer till it's flush. Seat the sprocket carefully and hand thread the crank bolt all the way to snug. I can't remember the torque spec.
    I recall it being like 45lb ft with a 90degree turn past the click but, I'll have to look it up in the morning though to be 100% sure.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Dec 06 2007
    Calgary, AB, Canada
    LOL, I guess I gave the simple version
    Good post, Brett. Just to add a little to what he said....
    Once you've got the bolt out of the crankshaft, use a 2 or 3 jaw gear puller to pull the pulley. haha "puller to pull the pulley" lol
    There are a few ways to pull seals, you can use a thin, flat head screwdriver and a mallet and pry them out, use the screw in the seal method (like Daft said), use the actual seal puller tool, etc. To seat new seals, you can either use a socket, or use a large flathead (with the blade of the screwdriver perpendicular to the seal) to drive it in.
    DON'T DAMAGE the sealing surface of the block (which touches the outer surface of the seal)
    The torque spec on the crank bolt is 200nm + 180*
    Mar 14 2007
    michigan
    I pulled the bolt out and the gear just dropped right off... I should be putting the motor back next week...
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by generationjdm View Post
    Yeah man, just like I said it would. I'm not sure why Jerbel needed a puller..
    Brett - Moderator
    Issue?: email me.
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    I tried getting the crankshaft pully off and it was a be-yotch. I left it on bc if it aint broke, dont fix it. *Knock on wood*
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by Daft View Post
    Sometimes it can take some convincing...
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by OldYella View Post
    Yes the pulley can be a bit tight around the crank sprocket bolt.
    The part that Genjdm and I were referring to was the crank sprocket.
    The sprocket is located underneath the pulley and the black cover.
    Brett - Moderator
    Issue?: email me.
    Aug 18 2007
    Ohio
    Yep, thats the same one i was talking about. I think it was because i had a slight waterpump leak and it was rusted on there pretty good. So i just left it alone.
    2002 TT Silver 225
    Veteran Member Three Rings Dcass08's Avatar
    Jul 21 2011
    Rochester NH
    I have an B7 S4 4.2 with a bad front crankshaft seal. How musch stuff has to come off before I get down to it?
    Veteran Member Three Rings mjb0023's Avatar
    Nov 15 2007
    69 camaro, 02 A4 Avant (stage 1+), 03 rs6 (stock), 14 q5 tdi
    Petaluma, Nor Cal
    Ive done it twice. its not too hard. just make sure you don't get the oem seal. get the rubber seal.
    silver 2001.5 S4 tip - Stage 3, Alcantara package, J-Fonz tuned ecu, GIAC Tip chip, AWE Twin 1, 3" DP's w/no cats, adjustable ST coil-overs, Bailey's DV's, APR Bi-pipe, r4s reps/ b6 s4 oem, M3 lip spoiler, RS4 Grille, RS4 motor mounts, , VDO pillar gauge, Porsche/Touareg 330mm bbk, rear 300mm bbk, racetec fmic,
    Active Member Four Rings
    Dec 11 2006
    Boston
    They are a pain in the ass to replace. A.) A bitch to get to, and B.) A bitch to put on properly. Similarly to the rear main seal in the way the seal must not fold over itself.
    Stage 3+ RS6's
