Results 1 to 9 of 9
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Who has RS4 clutches for the cheapest?
    I found one on ebay for $475, is that about average or can I do better? my car sounds like a screaming banshee so Im looking to go k04 by the end of June.
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Re: Who has RS4 clutches for the cheapest?
    Talk to Jordan(TheJerbel on here) and hell definitely hook you up. Very good prices and awesome customer service. I just ordered one through him and he was very helpful throughout the entire process, and i couldnt find it cheaper anywhere else.
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    What can the RS4 Clutch handle as far as hp/tq
    Senior Member Two Rings detroittechno's Avatar
    Jul 03 2007
    DETROIT BURBS
    I would go with the rs4 clutch vast has, kevlar FTW
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by audipotential View Post
    Clutches are rated in tq. And if I recall correctly, I'm pretty sure the RS4 clutch is rated at like 425 tq? (someone correct me if I'm wrong on that)
    Apr 18 2007
    b5 s4 nogaro , 1991 bmw 325is 5spd
    florida,wellington & hollywood
    call clutch masters and have them relign your stock clutch disk with stage 3 kevlar then find an rs4 pp and all other things needed to install ..... will save you a bunch of cash man and a reg rs4 clutch cant hold much man it was made for 380hp people toast them all the time id say skip and go with stage 3 clutch not the reg rs4 one
    cheers
    ---daniel
    Senior Member Three Rings kelticslob's Avatar
    Dec 08 2005
    Ontario
    Damn son, end of june? Went from K04 A4 to K04 S4 in a hurry!
    2000 1.8TQM: APR 93 Chip; 710N; Clear Corners; H&R sport/Bilsteins; Piano black trim; modified S4 front; 18" B7 RS4 rims/ Bridgestone Potenza S-03 Pole Positions
    2001 1.8TQS - stock
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Quote Originally Posted by kelticslob View Post
    I seem to be getting used to the power quicker and quicker, when will it stop!!!
    MITCH
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by Quattrocket View Post
    Never.
