Results 1 to 6 of 6
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    Anyone have a write up or how to on removing OEM wood trim?
    Want to have them custom painted. Some pieces come off easy but unsure about others. Any write ups or how to's? Looking to remove all interior wood trim pieces. Thanks much
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
    Feb 01 2008
    Missouri
    Re: Anyone have a write up or how to on removing OEM wood trim?
    Wondering the same thing!
    To get the center ash tray off you just pull from the top down and out-ish and it comes right off.
    The handbreak cover pulls right off.
    For the shift surroud you jam a putty knife (anything hard and flat) between and pry it up. Maybe the same for the parts around the handbreak?
    The door trim no idea? Hope thoes few bits help...
    May 04 2007
    LI,NY
    Yeah, all the center stuff is easy.. Its the door parts and the dash part above the glove box (where it says Quattro) I want to get some guidance on..
    Do all the parts by th 'E' Brake pop up easy??
    Veteran Member Three Rings BostonDriver's Avatar
    Sep 22 2004
    Massachusetts
    Feb 01 2008
    Missouri
    Thanks B-D and yes most of the center e-brake stuff just prys up I believe. One piece that i'm not sure about is the wood behind the armrest... in the back. Idk this post should let us know. I havn't opened it (noob mistake)
    I am surprized that this all can be done with a putty knife! I
    Veteran Member Three Rings bigmerle's Avatar
    Jul 27 2007
    2001 A6 Avant
    Annapolis, MD
