Results 1 to 3 of 3
    Jan 25 2008
    chicago
    help me out please
    ok while removing door panels one of my metal clips fell in how can i get it out?
    two when i removed my glove box there was a lot of foam that blocked my power wire to go through so i damege that foam.Does this foam has any effect on the car? It make me wonder as if it was part of the vantilation system perhaps?
    [can i use isolation tape for my power wire? to protect it from the water.
    Dec 06 2007
    Re: help me out please
    Thin long magnet??
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Unfortunately it is not likely you will be able to retrieve it.
