    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    Measuring Block 060 - Throttle Body Adaptation - ERROR
    Okay, got my GIAC chipped ECU yesterday and have been having some idling problems. Got access to VAG-COM today to do a TB Adaptation and when I checked Measuring Block 060, under adaptation it reads: "ERROR"
    When I swap back to my stock ECU and do the same, I get: "ADP OK"
    Anyone have any ideas as to what's wrong? Is the ECU shot?
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    May 04 2008
    Columbia, SC
    Re: Measuring Block 060 - Throttle Body Adaptation - ERROR
    Anyone?
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    definitely odd, is it coded properly, and where did you get the ecm from?
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    May 04 2008
    Columbia, SC
    I bought it second hand... Everything is coded correctly in the engine module... Is there any other coding I need to check?
    I'm hoping I didn't just spend that much money on a broken ECU.
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    just make sure you have it coded for a quattro/manaul. you have to look up on ross tech for the right numbers. i know when i bought my ecu secondhand, the guy had it coded for awd/manual, and so i threw it in and a cel popped up. i then found out it somehow got reset to fwd/auto. changed the coding and the cel was gone
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
