Results 1 to 4 of 4
    Established Member Two Rings 1145climber's Avatar
    Jul 04 2007
    MA
    Exclamation Help! ESC Light and Fault Code: Steering Angle Sensor
    Today my ESC light came on (solid, not blinking) so I hooked up my vag-com and ran the diagnostics... and here's the fault code it found:
    Address 03: ABS Brakes
    Controller: 8E0 614 517 Q
    Component: ABS/ESP allrad 4533
    Coding: 04595
    Shop #: WSC 06435
    2 Faults Found:
    01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
    35-00 - -
    00778 - Steering Angle Sensor (G85)
    37-10 - Faulty - Intermittent
    What gives? Do I have to take my car to the dealer, or is it something easily fixable?
    Jul 04 2007
    MA
    Re: Help! ESC Light and Fault Code: Steering Angle Sensor
    bump! help!
    Jul 04 2007
    MA
    now my ABS light is illuminated solid as well... someone?!?
    Sep 23 2006
    Houston TX
    Could be battery related. When I disconnected mine, those are codes I had when I reconnected it. If you clear them and they don't come back, I wouldn't worry. If they do come back, I guess trip to the dealership if its warrantied.
