Results 1 to 10 of 10
    Registered Member Two Rings
    Feb 10 2008
    RI
    Door Panel cloth help
    So summer is starting and i have started my summer projects. Im Redoing my interior and i wana do suede. But how do you go about doing the doors i see the piece that comes out but it has plastic rivets.
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Re: Door Panel cloth help
    You can melt those pieces and pull it off and then later plastic weld it back on.
    Feb 10 2008
    RI
    so i melt each one? with just a lighter or what?
    Oct 20 2007
    Not with a lighter. You can use a soldering iron and melt it.
    Established Member Two Rings ceas's Avatar
    Jun 12 2005
    Allentown, PA
    I just did this mod, and it turned out REALLLLYY good. I didn't even pop the inserts out. I took it apart as much as you did in your pictures, then I cut a template out from the suede and layed it over the existing cloth. After that I sprayed the existing cloth with spray on adhesive and stuck the suede template to it. After that I tucked the edges in with a flat head screw driver, it tucks in very nicely without even removing the panel.
    Pearl White 1998.5 Audi A4 1.8tQM
    Koni | Dahlback | Eibach | PolkAudio | Forge | MTX | Profile | Alpine | ECS Tuning
    Feb 10 2008
    RI
    wait so you didnt even take off the old piece?
    Jun 12 2005
    Allentown, PA
    Quote Originally Posted by coleA4 View Post
    nope
    Oct 20 2007
    I did that and about a month later it started to sag.
    Feb 10 2008
    RI
    yea im just gonna melt the tabs and take it off seems more efficient
    Feb 10 2008
    RI
    Aright i just melted the plastic rivets. It wasnt a good idea to take out the soldering iron when its 98 degrees out.
