Results 1 to 11 of 11
    Registered Member Two Rings
    Mar 25 2008
    Newton, Ma.
    Just replaced rotors and brake pads but...
    But why do i hear squeaking still? very weird and annoying...
    regards,
    lee
    Veteran Member Three Rings blackedoutt's Avatar
    Sep 16 2007
    B7 S4, MK1 TT, Tacoma
    Southern Indiana
    Re: Just replaced rotors and brake pads but...
    front sway bar bushings.
    YEAH BUDDY!
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Pad material may cause low speed squeeling.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Sep 16 2007
    Southern Indiana
    a squeak, or a squeal? they might just need to break in.
    YEAH BUDDY!
    Mar 25 2008
    Newton, Ma.
    i think its a squeal. it only happens from 10mph - 5mph
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Some pads ARE noisy. What did you use, since you didn't say originally?
    Feb 25 2004
    2002 TT
    San Diego
    Quote Originally Posted by InTTruder View Post
    Some pads ARE noisy
    x2
    Mar 25 2008
    Newton, Ma.
    I used oem brake pads and rotors...
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    How did you bed them in? There is a procedure, and you may know it, but it's not clear what you did from your posts.
    Mar 25 2008
    Newton, Ma.
    I didn't do it myself but is it possible that they need to be "broken in"
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    There is a prescribed process for bedding. Stops from 30, repeated several times. Do again at 50. Also try backing up at 10+ mph and then bedding in reverse several times. Some manufacturers differ, but everyone I know practices such a procedure. Once bedde, do a couple of hard stops to true them up in the caliper.
    Nonetheless, some materials squeal at low speeds.
