Results 1 to 6 of 6
Thread: A8 Problem's
    Veteran Member Three Rings live2shrednm's Avatar
    Jun 03 2008
    OLD: B6 S4 AVANT, B5 A4 1.8TQM
    Santa Fe, NM
    A8 Problem's
    Hey, I have an 2004 a8l that seems to be having some Park Assist trouble, for some reason when i first turn on my car it starts immediately going off when there is nothing even close to the front or back of my car. Does anyone have any ideas of what might be causing this.... Also i just realized the front passenger headlight ( secondary smaller xenon light next to the big headlight) has burned out. Is there anyway to easily fix this... If so what type of bulb is this... and how much will it cost.... Thanks so much
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Re: A8 Problem's
    Means you have a fault in the parktronic system. Easily explaind in the owners manuel. Need a vag to scan it.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Jun 03 2008
    Santa Fe, NM
    Re: A8 Problem's
    Thanks, anyone have any solutions about the small xenon headlight..... and any other ways to fix the Park assist....
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    Re: A8 Problem's
    Quote Originally Posted by live2shrednm View Post
    Unfortunately the only way I know is to take it to the stealership and...
    Feb 12 2007
    2001 Audi A6 4.2 (sold), 2010 Q5 3.2 (sold), 2008 Lexus IS250 AWD, 2011 Lexus RX350 AWD
    Unknown, AK
    Re: A8 Problem's
    A vag-com will tell you the fault code for the park assist.
    If you're technically inclined, perhaps you can replace the faulty sensor (if that's what the code reads) and complete the circuit, so it works properly.
    Other than that, dealership will want some of your hard earned money to fix it right.
    Jun 03 2008
    Santa Fe, NM
    Re: A8 Problem's
    Ok thanks guys, i dont have a vag-com, but I have learned to get used to the park assist problem, and i am currently getting different price quotes for fixing the headlight..... Cant believe that it may be in the 500-900 dollar range for a damn headlight.Any other suggestions would be appreciated.....
