Results 1 to 6 of 6
    Jan 25 2008
    chicago
    please help me with my sub installation with pictures is damaged?
    ok while removing door panels one of my metal clips fell in how can i get it out?
    two when i removed my glove box there was a lot of foam that blocked my power wire to go through so i damege that foam.Does this foam has any effect on the car? It make me wonder as if it was part of the vantilation system perhaps?
    [can i use isolation tape for my power wire? to protect it from the water.
    Jan 25 2008
    chicago
    Re: please help me with my sub installation with pictures is damaged?
    bump bump how can i get this clip out ;(
    Veteran Member Three Rings Kschroers1's Avatar
    Jan 12 2008
    17' Jeep Grand Cherokee Limited 1942 Edition, 12' A4 Premium S-Line 6spd Quattro
    Roanoke, VA
    your probably not going to if it feel down into the body of the car. Your sol and will haft to get a new clip. And why are you running your positive cable like that? not a real clean/stealth look to be honest.
    2012 Audi A4 Quattro 2.0T 6spd Premium / S-Line / Ibis White/Tan Interior
    2017 Jeep Grand Cherokee Limited Willy's Edition / White
    Dec 27 2005
    New Orleans
    lol dont worry about the clip..its gone! you will have to buy new ones. I lost a couple like that also, but if your carpet/plastic still attaches firmly to the car without any major gaps or loose fitment..then i would just forget it.
    Dec 27 2005
    New Orleans
    as far as the power cable.. i would wrap it in black wire loom and move it around the battery so it wont be on the top of the battery. here is how i did mine:
    Veteran Member Three Rings Jay B7's Avatar
    May 08 2008
    2005 S4 Avant Quattro; 2014 Honda Pilot Touring 4WD 2007; GSXR 600; 2019 VW E-Golf
    SF Bay Area
    Not to flame or anything but here's a good example of why you should not DIY with no experience.
    Tap, Snap, or Nap!!!
    2005 B6 S4 Avant; 2007 B7 A4 2.0T Quattro; 2007 GSXR 600;
