Results 1 to 8 of 8
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Odd metal on metal sound when turning right???
    Just like the title says... Odd metal on metal sound (like a stationary sander to a metal pipe at low rpm) when making an aggressive (just pushing it enough to load up the front left tire) right turn. Does not make a sound when taking an aggressive left turn or when taking an easy right turn. I have a 99 Avant 1.8 w/ stock sport and 78K miles. I jacked the car up to take a look under the front of the car and saw nothing loose or signs of something rubbing. All the boots and control arms looked good. Kept the wheel on the car and jacked it up and shook the wheel grabbing the 9 and 3 position and the 12 and 6 and no real movement. My car is an Avant and road noise seems about normal. Wheel bearing??? Shocks are worn but what else can I check?
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Dec 14 2006
    Halifax, NS, Canada
    Re: Odd metal on metal sound when turning right???
    sounds more like outer CV joint
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Veteran Member Four Rings Wholsea's Avatar
    1998 Audi A4 1.8tqms
    Blacklick, OH
    Is it kind of clicking or clunking?, or is it a continual scrape? Err, does it seem rotational...
    1998 A41.8tqms
    Oct 03 2007
    02 BMW 330i
    Illinois
    Quote Originally Posted by Wholsea View Post
    It is definitely more of a continual scraping/rotational sound. I've had CV joints go bad on other cars (VW's Mk1 and Mk2) and this is not a clicking or clunking sound at all. Thanks for the help...
    Blacklick, OH
    I'd say pull the wheel, check the 17mm bolts that hold on the carriers and make sure they are good and tight.
    Make sure the pads are seated properly
    Make sure suspension bolts are tight
    Put wheel back on (torque to 75 ft lbs)
    Verify your power steering fluid level (Engine bay, drivers side of car, green lid)
    A wheel bearing would be more of a hum, and you'd hear it all te time, and it'd go away when you took load away from that corner.
    I suspect it might be something in the steering. Maybe low fluid...
    1998 A41.8tqms
    Registered Member Two Rings
    Apr 19 2008
    215 PA
    most liikely your tie rods are seized
    Oct 03 2007
    02 BMW 330i
    Illinois
    Quote Originally Posted by baboom View Post
    I am going to replace them with some of the newer heavy duty tie rod ends next weekend. I think they are worn and have some, some play when I jack the car up and shake the wheel holding on to the 9 and 3 o'clock position. What do you mean by seized???
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Double check your exhaust too. I had this and it was my exhaust rubbing on something underneath my car since a hangar broke.
