Results 1 to 10 of 10
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    went to change DV's today...
    doesnt seem like much of a job but i have one question
    what size clamp do i need to replace that on that is on the top of the DV
    sorry i dont know what its called
    its one of those damn one time use thingys
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Re: went to change DV's today...
    I didn't even put a clamp on those. If you replace those hoses with the same size tubing it will be VERY snug to even get on there. For insurance I just put small zip ties on them and called it a day, you will be fine.
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    so i should get new tubing for it?
    or can i use the same thing and just tip tie it?
    and what about the other side and how its like woven?
    same deal?
    thankjs for the quick reply
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Feb 19 2007
    La Crescent, MN
    I personally would just replace all the tubing you can just for peace of mind. The tubing is dirt cheap at just about any hardware store. It more than likely wont be braided like the factory stuff but that doesn't matter. I think you will find that once you take that factory stuff off and try to put in on the new DV's it will start separating and cracking and not give you a good feeling about it. At least thats how it was for my A6 when I did the DV's.
    So yeah I would replace and then just use mini zip ties and you will be golden :)
    Registered Member Two Rings
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    The vacuum line that connects the two DV's should be replaced. I used the original tubing and it split open twice. The Forge 007 nossles are much larger than the stock DV's, causing the line to rip. For $1, might as well replace. I don't even have them zip tied and the stay snug just fine.
    GIAC Flashed ECU++++FORGE 007 DV's++++ECS 2 piece Front and Rear Rotors++++SS lines++++VOGTLAND GT's
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    ok
    i got the 710N's so i didnt get the 007s
    but what size is the tubing and what should i ask for when i go to the hardware store?
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    its 3mm vacuum hose... just bring the nonbraided hose into the store when you get there and they'll bring you the right size. i have 007s and nothing holding them on, no problems. also read the DV/BOV sticky thread
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Registered Member Two Rings my_01_S4's Avatar
    Jun 20 2007
    Silicon Valley, CA
    FWIW, those weird clips supposedly require a special tool for them but you can use other tools to compress them should you decide to use those clips.
    Zip ties also work which is what I used.
    Sep 17 2008
    2001 Audi S4
    Mary Land
    small zip ties, but as long as its snug don't worry about it, just get it on all the way.
    Senior Member Two Rings Luca12's Avatar
    Sep 16 2007
    00 b5 s4
    jacksonville, fl
    You probably want to replace the the vacume line with the woven stuff on it because it will hold moisture and rot the line.
