97 degrees here today and my AC is blowing warm air. The compressor and fans both are operational. Where else should I check for trouble? Should I just refill the refrigerant and check for leaks? Can a faulty coolant temp sensor affect the AC ? My coolant gauge has behaved erratically once before when I was low on coolant because of a small leak. It went back to normal after the coolant was refilled though. TIA
