Originally Posted by
B7!
i just bought one myself. can you tell me how you installed it?
thanks
Just follow APR's installation instructions from their website. Here's the link:
http://goapr.com/Audi/support/b6_snub_mount.pdf
It says "B6 Snub Mount", but the installation is exactly the same for B7's.
Step 6 says to "Loosen the FOUR 13mm nuts holding the snub basket to the front clip"....B7's only have THREE 13mm nuts on there. To make it easier to reinstall the snub bracket, I removed the snub basket from the front clip and reinstalled them both together. There's no muscle or fighting involved to get it to fit. It should just fit, if you're fighting...you're doing it wrong. Tighten the snub bracket, but don't tighten the nuts down on the basket, just finger tight. The basket should still be able to slide up and down. Crank the car and let it idle, then tighten down the 3 nuts on the basket. That lets the basket get centered up around the APR snub.
Something I noticed in another AZer's snub installation post is that he installed it backwards. The lip on the inside of the mount that slides onto the shaft of the lower engine bracket is not equally spaced. The "deeper" side of the snub should face towards the engine. The very tip of the lower engine bracket should stick out (just a little) past the end of the snub itself.
Here's a picture from the other post....this is wrong. It should be the opposite.
I should've taken pictures and done a write-up for you guys, but I didn't think about it. It's really not a hard installation at all. The underbody trays are the hardest part.
I have zero "extra vibration" at any RPM, so I'm not sure what that's all about with the other guys that have installed the snub mount (for any brand...not just APR).
