Results 1 to 4 of 4
    Veteran Member Three Rings LEGO's Avatar
    Aug 20 2007
    SEATTLE, WASHINGTON
    wastegate actuator
    Just want to know if anyone knows if the wastegate actuator from the ko3 and the ko4 is the same. Thanks!
    1998 A4 1.8TQM MTM K04 5.82/034 415CC BT TUNE/GENESIS 415CC INJECTORS
    http://s22.photobucket.com/albums/b331/nelly11299/
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Re: wastegate actuator
    Im pretty sure it is.
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    yessir.
    82mm je pistons, scat rods, ported & polished aeb head. gt2871r, atp hi flow manifold (ported). 580cc injectors on custom giac tune. Once you boost, you'll never go back....
    Aug 20 2007
    SEATTLE, WASHINGTON
