Results 1 to 6 of 6
    Registered Member Two Rings
    Oct 17 2007
    White Plains NY
    HELP!!! Messed up Engine or Exhaust or IDK!!!
    Hey everybody,
    I have a 1999.5 B5 Audi A4 1.8T Quattro. I was driving around today fine and when i went to back into the drive way i put the car in neutral for a second and realized that the car sounded like a F***ing gokart! I felt a major loss of power(felt like i was running a 10hp engine!) The car was making a clunking sound. I got out of the car and opened the hood. the engine had the normal sound that it usually does except for a sputtering clunking sound from the exhaust. DONT KNOW WHAT TO DO! any suggestions would be valued greatly.
    Thank you,
    IAN
    Senior Member Three Rings fatty1.8t's Avatar
    Mar 04 2007
    2003 A4 1.8t
    Birmingham, Alabama
    Re: HELP!!! Messed up Engine or Exhaust or IDK!!!
    coilpack
    AZ Schmeckles Member #1. OG status in this bitch
    APR 1+, custom exhaust with magnaflow 14851s, intake, test pipe, sub, koni coils, rs4 sway, 17'' oettinger re's
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Quote Originally Posted by fatty1.8t View Post
    coilpack
    I had the same issue but mine had a flashing CEL and it was a bad coil pack causing a misfire on one of the cylinders.
    Feb 27 2005
    North Wales, PA
    ignition control module
    Dec 17 2007
    MI
    Check spark plugs. You can loosen the coil packs, start the engine, and lift one at a time and see which one that does not cause the engine to hesitate. I had the same issue a couple of weeks ago.
    Oct 17 2007
    White Plains NY
    Thank you to all of you guys. I took the car into a local shop that i trust and they tested the gas. they said that there was a misfire in one of the cylinders, and bad gas. that blew my mind because i only put 93 oct. in the car from Mobil. The problem looks like it is fixed so thank you guys for all the input
