Results 1 to 19 of 19
Thread: Twin disc setup
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Twin disc setup
    Who has any experience on the S4 with running a twin disc, post any info you may have and the pros and cons of each twin disc setup
    In Limbo Two Rings
    Apr 19 2008
    Utah
    Re: Twin disc setup
    I am getting ready to buy one. i know that the twin disk from asp is going to be on and off style because of the diskes are have sold hubs and no springs and they are ceramic. i know from experiance with all the other clutches i have had. i just know that it is the only way to go for big turbos and alot of clutch cycles. they can handle alot of heat, the hotter they get the harder they bite. plus i trust tilton alot. what is your thoughts on it.
    Mar 14 2007
    michigan
    Re: Twin disc setup
    I had the tilton a while back and the car really wasn't drivable at all on the street.. This was on a honda though
    In Limbo Two Rings
    Apr 19 2008
    Utah
    Re: Twin disc setup
    I have had one side kevalre and one side cermaic on my ko4 s4 with 75 hp juice and it kicked the kevalre sides butt. that is why i am going to the twin disk with cermaic. btw your manifolds are the goods! You are a True Craftsman. how bad was the honda
    Mar 14 2007
    michigan
    Re: Twin disc setup
    The honda was crazy a little over 500whp on 93 octane at 22lbs
    In Limbo Two Rings
    Apr 19 2008
    Utah
    Re: Twin disc setup
    Wow bad boy honda! was the twin disk on and off ? either ingaged or disingaged?
    Mar 14 2007
    michigan
    Re: Twin disc setup
    Ya the thing was like a switch, there was no way to ease out the clutch... That was 8-9 years ago when i did that
    In Limbo Two Rings
    Apr 19 2008
    Utah
    Re: Twin disc setup
    I spoke to JP from vag on the phone the other day, and he said that he liked his clutch masters ceramic twin. He said that he has had some problems with the kevalar holding up with the big turbo set up.
    Mar 14 2007
    michigan
    Re: Twin disc setup
    Spec makes a twin disc in 3-4 different configs
    In Limbo Two Rings
    Apr 19 2008
    Utah
    Re: Twin disc setup
    what is there price range? do you know?
    Jan 11 2007
    Salt Lake City, Utah
    Re: Twin disc setup
    Yeah, you guys want to post prices for the ones that you are thinking about? I looked for a sec at the clutchmasters and it was like $1800-1900 IIRC
    Mar 14 2007
    michigan
    Re: Twin disc setup
    Retail for cm was like 2400 retail for spec was 2000.00
    Active Member Four Rings NYCVR6's Avatar
    Queens, NYC
    Re: Twin disc setup
    I should know in 2 weeks, i have the tilton setup. Shaun we got the other downpipe tacked up today, but it was too damn hot here to continue. He is going to weld it up for me this week, and ill go back to button everything else up.
    Justin- 01.5' Pearl S4 24V VR6 Turbo Pow Pow
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Drive your car, not your dyno sheet
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    Re: Twin disc setup
    I have now custom made flywheel and AP-Racing twin disc sintered clutch, 950 Nm. Price was ~2600$.
    This has integrated pulse teeths, not like in the Clutchmasters or others. Those will definitely stay there, I have heard that the pulse ring might sometimes take off. It is also made from steel, that should help in chattering, and it is also stronger than aluminium.
    Not installed yet, so I can't tell how does it feel.
    http://valitalo.org/images/engine_tu...l_fw_front.jpg
    http://valitalo.org/images/engine_tu...al_fw_back.jpg
    http://valitalo.org/images/engine_tu...ng_clutch2.jpg
    http://valitalo.org/images/engine_tu...ng_clutch3.jpg
    http://valitalo.org/images/engine_tu...ng_clutch4.jpg
    Mar 14 2007
    michigan
    Re: Twin disc setup
    Quote Originally Posted by NYCVR6 View Post
    Did check to see if the dps extra 02 sensor i put in is in the right spot now since the dps have been modified? If not cap it off and have him do another one for you.. Hope to see it up and running soon, as for mine I finally started playing with the motor, hopefully have it back together in 7-10 days.
    Veteran Member Three Rings cjk's Avatar
    Jul 15 2004
    2001 WB S4 Avant
    Seattle, Wa
    Re: Twin disc setup
    Quote Originally Posted by generationjdm View Post
    Nice work man! :) Good to see you finally have time to touch your car
    Queens, NYC
    Re: Twin disc setup
    On the drivers side it's pretty close to the tranny, but ill make it work.
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: Twin disc setup
    Quote Originally Posted by Cobrakiller08 View Post
    hmmm... with a name like cobrakiller, this has to be Chris?
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    Re: Twin disc setup
    Spec from atlanta?
    let me know if you run this setup, i have a Spec setup on my integra (stg5/lwfw) and i love it. I didnt know how it would be on a S4, not that I need a new clutch setup yet.
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
