Results 1 to 8 of 8
Thread: Hub Rings
    Registered Member Two Rings MaximusS4's Avatar
    Nov 04 2005
    Boston
    Hub Rings
    Hi,
    I've got a little situation. I've got a set of BBS CH BE's but I never got the matching hub rings. Now they are out of stock with the BBS distributors, Tirerack and whoever else. I need them somewhat urgently for an event that my car is entered in...
    They are model# 82/57M PFS
    I figure that means that the rings have an outer diameter of 82mm and inner diameter of 57.1mm. I don't, however, know what the width of the rings should be. If I can't find adequate rings in the next couple of days, I will have them machined. I'm guessing I should use Aluminium?
    Any input would be greatly appreciated!
    Best,
    Max
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    Re: Hub Rings
    go to your local discount tire or local tire shop and tell them the size you need, measure the hub and tell them you need a hub ring that goes from xx.xx to 57.1
    Nov 04 2005
    Boston
    Re: Hub Rings
    NO ONE has 82mm
    I have have made over fourty calls in the last two days.
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    Re: Hub Rings
    Have you called BBS directly? I think they sell the rings clips and lug bolts for $40
    Nov 04 2005
    Boston
    Re: Hub Rings
    ring clips and lug bolts yes... they're out of stock on rings.
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Re: Hub Rings
    very unfortunate dude. the CH BEs are wicked in person are they not? what color is your car?
    good luck with the rings
    Mar 24 2007
    Re: Hub Rings
    try Thatcher at Speed warehouse
    Nov 04 2006
    05 S4
    LI, NY
    Re: Hub Rings
    what about the vendor here that is selling the BBS CH Black editions....can you contact them and ask to purchase a set from them???
    Oetty roof spolier // FI Catback // Ecodes // Xenon Interiors // Solaris and LED Exteriors // Lower Euro-grille // ECS Snub // PSS9s // 19x8.5 BBS CH on 245 Potenzas // Euro RS4 Exclusive shift knob and Pedal Set // Carbon Fiber Trim // Custom Carbon Fiber Emblems
    Originally Posted by Justincredible
    "With the flux mod you can just put the supercharger in the trunk for extra traction"
