Results 1 to 8 of 8
    Established Member Two Rings Sobo's Avatar
    May 14 2008
    S4
    east aurora
    Arrow Power Steering! Help Me!!!
    1997 Audi A4, Quattro, Manual, 1.8l turbo
    So I left school yesterday, noticing a whining noise...So i get home, check my fluids and find out my power steering reseviour is low and it has bubbles in it...So I go and buy Power steering fluid and leak stop.. Used a whole quart.
    Today, I bought a new quart of power steering fluid and then a bottle of lucas oil.So, I fill her up, use the entire bottle of lucas oil as the day progresses and now I'm home and look on the driveway...
    I see this!
    What is wrong!?
    Help me...
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: Power Steering! Help Me!!!
    Don't ever use leak stop number 1...
    But that looks like you need to change a steering rack... Pull the wheels and check the boots on the rack... I bet they are filled with fluid...
    ΜΟΛΩΝ ΛΑΒΕ
    May 14 2008
    S4
    east aurora
    My rack boots are dry.
    The oil squirts out, indicating pressure.
    The pump is fine.
    Does this mean my cars pressure hose is leaking?
    Mar 04 2007
    nothing
    nowhere
    Well, if it is squirting out, WHERE is it squirting from?! Go take a look!
    ΜΟΛΩΝ ΛΑΒΕ
    May 14 2008
    S4
    east aurora
    nvm...
    Confirmed to be the rack..
    I re-felt the rack boot, farther backed in was oil soaked...
    I cut the ziptie off the boot end, and slid it off, and a ton of power steering fluid gushed out.
    Whats a fair price to have a rack done?
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    you might not want to ever again use regular power steering fluid.
    You probably either want a local rebuilder or a reman'd rack from a reputable place.
    i ordered a rack seal kit from rock auto and took it to the local rebuilder total cost was around $250 2 years later still no leaks.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Mar 04 2007
    nothing
    nowhere
    You have to be careful with the rebuild kit though... When mine leaked, the shaft comming out had some pitting corrosion on it... This chewed up the seals so the whole rack needed to be replaced.... If you do seals with something like that, look forward to leaks again in the near future...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Quote Originally Posted by Ewok_Fetus View Post
    Same happened to my brothers MK4.
    Notice the zip-tie? Previous owner/mechanic did this and a zip-tie does not seal nor hold. Use a metal clamp!
    Get a remanufactured rack. Its a real pain to replace tho.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
