Results 1 to 4 of 4
    Veteran Member Four Rings jursch2211's Avatar
    Feb 05 2008
    Illinois
    Starting problem
    Ok so I don't know what this could be. I tried starting my car yesterday but it wouldn't start. It would crank and crank but would not start. Does anyone know why this might be? TIA
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Re: Starting problem
    Try the fuel pump fuse. Open driver's side door and take off that plastic panel in the corner. There is a key on the inside that tells you which fuse it is.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    If the fuse is good, turn the key on a listen for the pump to hum on the pass. side rear seat.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 05 2008
    Illinois
    yep it does all that. The rpm's jump a little when i'm trying to start but it just won't give. I've had a few rough starts in the winter but its spring/summer now so I shouldn't have this. I'm thinking it might be time to replace spark plugs but I don't think that would be the reason but it might be. I'm going to try again today and i'll let you know what happens.
