Results 1 to 3 of 3
    Mar 21 2008
    Porsche Wheels Will they fit??
    Also in Wheel section just tryin to get a fast answer
    http://www.audizine.com/forum/showthread.php?t=215948
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    Re: Porsche Wheels Will they fit??
    Quote Originally Posted by looseboost View Post
    dont do it..You will need adapters and they will make them poke out even more..Unless you are a fan of rolling the hell out of your fenders i would reconsider
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    First find out what offset they are, based on that you can determine if they would fit with adaptors. But chances are that its a low ET and then you add 25mm spacers and they will not most likely fit. If they turn out to have an ET of 51 or something, then could fit. Hope that helps a little.
