Results 1 to 3 of 3
    Registered Member Two Rings
    Jan 26 2008
    00' S4 M6 blk/blk
    columbus, OH
    Do i have an issue (heat)?
    Hey guys whats up? Ive noticed increased temps while driving recently. Ive only owned the car for about 3 months. During the previous cooler months my oil temperature reads around 150-175. Over the last two weeks i notice my temp levels at 200 degrees consistently. At one point, i believe that i have even seen them as high as 225. I drive a 2000 S4 with 48k.
    The biggest concern that i have is that the car sounds like a semi everywhere i go now. It sounds like a big cooler or something just going "wooooshh" whenever i accelerate. What the hell is this and what is the problem?
    Thanks guys!
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    Re: Do i have an issue (heat)?
    190-210F is perfectly fine, my temps fluctuate 15-20 degrees during the seasons aswell, if it gets near the 250+ range, start to be concerned
    My car is fast
    Apr 05 2007
    Quote Originally Posted by supasuprase View Post
    Thanks guys!
    oil temp is fine at 225 - just check the oil level to make sure you aren't running low.
    the 'whoosh' is something to look into right away. more than likely you have a boost leak. do a search here for 'pressure test' to see how you can find the leak.
