Results 1 to 2 of 2
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    Question Need some rim help!
    What is the correct offset for B7 A4's?
    May 22 2008
    2013 Audi S4 IceSilver MMI/SD/DSG/AK
    Bay Area
    Re: Need some rim help!
    Check the FAQ at the top of the B7 Forum it lists the all the default Offsets. Generally you want around 40 offset, all the aftermarket rims I have looked at are 35 offset. I also believe the VMR wheels are 35 that are for the Audi A4. Good luck hope this helps.
