Results 1 to 10 of 10
    Mar 28 2008
    Northern NJ
    Question Cr-v Engine Swap? PLZ Help
    hey guys my dads 2000 CR-V has a misfiring cyclinder and the engine is shot to shit. Im looking to swap it with a a replacement and suggestions of stuff to be aware of? like just general knowledge because this will be my first Swap. THANKS!
    ~~RR 686
    Veteran Member Three Rings DGS4's Avatar
    Apr 28 2004
    fast legs
    Re: Cr-v Engine Swap? PLZ Help
    Quote Originally Posted by Retard Riot View Post
    ~~RR 686
    Basic B20 motor. You should be able to swap motors from another CRV without any issues. I doubt your father is a performance freak and would like to keep it stock, So I suggest scour the yards for a B20 long block.
    Its an easy swap. Disconnect all the lines, empty out the anti freeze, take out the axles, drop the 4 mounts. Slide up, swap over harnesses and other parts, Slide down. Bolt back up and done.
    You could probably sell the short block to some B20vtec freak on the honda forums for extra change after the fact.
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Screw that go with a K-Series (RSX, TSX...etc) motor. B-series is so fanboy!
    Mar 21 2008
    a kseries in a crv?? wtf??
    B20 long blocks can be found for cheap. Very simple swap just rember where the vacuum lines go. the harness is easy to replug in.
    Apr 17 2007
    B8 A5
    Quote Originally Posted by looseboost View Post
    Hell yea! V-TAK BABY!
    Apr 28 2004
    fast legs
    Quote Originally Posted by tike0rz View Post
    LOL !!!!!!!
    Mar 28 2008
    Northern NJ
    hahah thanks so much guys it will be my first so hopefully it goes well. and yes the old man doesnt need anything special... after all its his fault he went with jap crap and not German engineering :)
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Jap crap... Wow.
    Good luck with that install, it's cake you retard.
    Apr 28 2004
    fast legs
    You can probably diagnose the motor for the misfiring. Probably a bad distributor coil, plug or wire. Why dont you do a compression test and find out first before you butcher the car.
    Also, Honda > Audi in relaibility overall. So I dont know what "Jap Crap" your talking about.
    Account Terminated Four Rings Gundem's Avatar
    Nov 08 2005
    A4 2.8 Type-S(low)
    Los Angeles, CA
    my thoughts exactly.
    ignore fools like IloveT. there is a reason CR-V's are still in demand and audi 100's aren't. Nah mean?
    shit i don't even think IloveT has an audi,
