Results 1 to 6 of 6
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    ss braided water/oil lines
    i know some of you guys dont fork over 300+ for pre-fabbed stainless steel oil feed/return and water lines, so my question is where did you buy your parts. looked a little on summitracing but that site always confuses me.
    thanks
    ::2002 S6
    Feb 27 2005
    North Wales, PA
    Re: ss braided water/oil lines
    i just use standard fuel rubber lines for the coolant from the auto store. They hold up just fine. you can piece together your lines with an fittings. -10 for the oil return and -4 for the oil feed.
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    just found these beauties, to bad they come with a hefty price tag to...
    http://www.russellperformance.com/mc...ose_ends.shtml
    ::2002 S6
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    also on the chra, the two water holes are threaded what fitting do i put in there? im assuming atp has it but just want to make sure what size, also does it mater which is the feed and which is the return? both look the same.
    ::2002 S6
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    I bought my stuff from ATP but I WOULD NEVER suggest them, the woman that claims she owns ATP is a complete bitch. I had both my orders messed up and she hung up on mw twice, honestly I wouldnt deal with them b/c the customer service could NOT be any worse. But FWIW its much cheaper to peice together a kit than buy the one from 034. You can price one together for around $200
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    yeah get all my braided lines through a liquidator store. you can try a hydraulic store that should have all the different style of hoses available. get your an fittings from ebay, much cheaper & still hold fine just like earl's stuff & a fraction of the price.
    82mm je pistons, scat rods, ported & polished aeb head. gt2871r, atp hi flow manifold (ported). 580cc injectors on custom giac tune. Once you boost, you'll never go back....
