Results 1 to 14 of 14
Thread: 24's on a Q7
    Oct 09 2005
    24's on a Q7
    does anybody know if I can fit 24's on the Q7without modification? I went to the rim shop and I went with the intentions of buying 22's but they told me that 24's will fit. I need help before I order the wrong stuff
    May 20 2008
    Berlin
    Re: 24's on a Q7
    Quote Originally Posted by bigelv View Post
    Yes 24" do fit - although 24" do not look as good as 23" ;D
    Most of the 24" are only 10" wide and the 23" are 11" wide.
    For 10x24" with (probably 295/40/24 or 315/35 R 24) check out these pictures:
    For 11x23" with 315/25/23 look at these:
    Regards
    Chris
    AVUS PERFORMANCE
    Veteran Member Four Rings Monchichi8's Avatar
    Jul 03 2004
    2004 S4, 2005 Grand Cherokee Hemi
    Boulder,Colorado
    Re: 24's on a Q7
    WOW! those wheels are hott! especially on the Q7
    Oct 09 2005
    Re: 24's on a Q7
    they told me i would have to go with a 275/25/24 for a 24x10 wheel
    Jun 27 2007
    san jose, ca
    Re: 24's on a Q7
    Just be careful, running on 24s makes the ride much harsher and there is a greater risk of bending wheels at that point with that little rubber.
    May 20 2008
    Berlin
    Re: 24's on a Q7
    If you take the Pirelli Pzero Nero in 275/25/24 - that tire has a load rating of 91W. That is way too low for the weight of the Q7. The Q7 needs a tire with a load rating of at least 100. I recommend 295 for 10" rims - You can choose 295/40 or 295/35 which looks better...
    For example the 295/35
    http://superbuytires.com/tires/model.../Parada+SpecX/
    Load Rating: 117V
    That is definitely enough for the Q7
    Regards
    Chris
    AVUS PERFORMANCE
    Oct 23 2007
    Pleasanton, Ca
    Re: 24's on a Q7
    What is the ride quality like for going with such huge wheels?
    Veteran Member Three Rings blkNJ a4's Avatar
    Apr 23 2007
    99 A4
    new jersey
    Re: 24's on a Q7
    23 ftw
    Schmutzig V.A.G.
    Aug 09 2004
    Orange County
    Re: 24's on a Q7
    i'm pretty sure those rinspeed's are 23's
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: 24's on a Q7
    WOw they look hot!!!
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    May 20 2008
    Berlin
    Re: 24's on a Q7
    Quote Originally Posted by Mr. Chang View Post
    Amazingly good - at first I also thought it would be much worse. The opposite is the case - every customer that bought the 23" Rinspeed wheels was absolutely satisfied. Not only is the ride quality very good - the wheels do fit perfectly to the car. The wheels are 11x23" ET50 with 315/25/23 - avaiable for VW Touareg and Porsche Cayenne also. In my opinion they look like 24" if you compare it with the other pictures.
    Quote Originally Posted by blkNJ a4 View Post
    23 ftw
    Yep 11x23" ;D
    Quote Originally Posted by bkquattro View Post
    You're also right :p
    Regards
    Chris
    AVUS PERFORMANCE
    Veteran Member Four Rings skunkoncrunk's Avatar
    Apr 18 2007
    2006 Subaru WRX
    Cali/Colorado
    Re: 24's on a Q7
    Quote Originally Posted by MTMBerlin View Post
    That's pretty tight.
    -Hooked on Meth-
    BOOSTADCT
    -Mike-
    Instagram: @mdundurs
    S4's Video (Watch in 1080p)
    Rest in Peace Four Rings adam's rotors's Avatar
    B9SQ5 | B9S4 | HD FXLRST
    Re: 24's on a Q7
    hate the face style on those vellanos, but they are a GREAT wheel, and looks fuckn baller on the Q...jesus
    adam | adam's rotors inc. | [email protected] | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    Re: 24's on a Q7
    wow, those look baller!
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
