Results 1 to 7 of 7
    Veteran Member Three Rings mmxruffryder15's Avatar
    Mar 28 2008
    new york
    problem with my brakes
    yesterday i smelt a burning smell from my car nd behold it was from my brakes...my rotors were starting to turn blue nd my pads were turning white from burning...all of this on my rear left wheel...wat can this be my brake line or my caliper???
    Registered Member One Ring mrrod420's Avatar
    Jan 18 2005
    B5 S4
    Detroit
    Re: problem with my brakes
    Sounds like the caliper is ceasing up.. Happened to me and waited too long and had to buy a new one
    Mar 28 2008
    new york
    iight thanks...bout how much is a new caliper
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    agreed. look for a used one and rebuild or go to NAPA. they have them for like $200+core rebuilt. just went through similar situation, but mine wasn't so bad. i luckily found 2 used rotors that had like 30k miles on them, which is fine by me cause they'll only be temporary.
    Also,make sure your rotor is warped. if you're not sure, take the rotor to a machine shop and have them measure the run-off. if it's waaayyyy bad, they might not be able to machine the rotor back to spec. in which case, you'll need to buy new rotors.
    until all that is done, try to drive easy and not slam on your brakes too bad.
    Mar 28 2008
    new york
    yea its my calipers i bought a rebuilt...my rotor nd pads were fine luckily
    Veteran Member Three Rings NOVAS4's Avatar
    Sep 02 2007
    2003 Audi RS6
    Woodbridge, Virginia
    i know this thread has been dead for about 5 months but this same thing is happening to me.. i found this http://www.autopartswarehouse.com/de...QA1192758.html ... they are cheaper i have ordered rear calipers from them before and are great quality
    Current: 2003 Audi RS6
    Current: 2008 Acura RDX Tech (daily driver)
    Previous: 2013 Hyundai Genesis Coupe 3.8, 2006 Acura TSX, 2008.5 Mazdaspeed3, 2000 S4 Sedan 6sp stage3-, 2004 Subraru WRX
    Sep 02 2007
    2003 Audi RS6
    the picute is universal but product is not
