Results 1 to 6 of 6
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    maybe a dumb MAF question
    if im throwing a MAF code and the car runs like shit can i just drop the new sensor in and it will be good? do i need to unplug the battery or clear the codes or anything specific? the reason i asked was i bought a sensor because of the code and hesitation i was getting. i installed the new one and went to hammer it and it did the same thing. i didnt have my VAG to clear the codes. i can see maybe not clearing the codes making a difference but someone said to unplug the battery. i cant see that making a difference but who knows at this point lol. also EPL said to cut holes in my airbox, that could be my problem but why and the hell would the car run strong one day and then not the next if that was an issue? any advice is appreciated at this point.
    Dec 06 2007
    Calgary, AB, Canada
    Re: maybe a dumb MAF question
    Clear the codes with VAG and see what happens.
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    probally still running on a defaulted maf signal, gotta clear codes most likely.
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    re-post when you resolve this
    My car is fast
    Jan 30 2007
    2000 S4 stg3
    cincy
    Make sure you have the Oring inbetween the MAF and the airbox and make sure they didnt send you a 90mm MAF instead of an 85mm one.
    Senior Member Three Rings GyzmoS4's Avatar
    Feb 07 2006
    Bronx, NY
    When i changed my maf, the cel came off on the next start up. Didn't have to unplug the battery or anything. But, i was driving with the bad maf plugged out for a while prior to changing it. Don't know if that made a difference at all.
    J-Fonz tuned Stg 2+
    "Two wrongs don't make a right, but it makes us even."
