Results 1 to 16 of 16
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    my fmic mounted and plumbed.
    need to get the mounting brackets removed and rewelded further back so the bumper fits better..so far i'm happy with it.
    -Luis
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    Re: my fmic mounted and plumbed.
    what core did you use?
    ThorTechnik.com
    Mar 20 2008
    Italy
    That's a TREADSTONE Fmic ;)
    I think you mounted it a little bit too high!
    However, good job!
    Nov 02 2005
    S4
    VA
    yeah it's a custom fmic with treadstone core and endtanks.. i originially mounted it lower but the bumper didn't fit all that well...so now it's higher and the bumper fits better but the brackets could still be pushed back an inch or to so the bumper fits like it should.
    -Luis
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Spray on black Plasti-Dip on RS4 grill surround FTMFW! Black paint FTMFL!
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Veteran Member Three Rings saucys4's Avatar
    May 30 2007
    San Diego/SF Bay Area
    clean install but that is a weird looking core.
    J Fonz Stage II+
    Veteran Member Three Rings RuS4ty's Avatar
    Mar 13 2006
    VA / MT
    good work luis, now go respray the grill please.
    Seeing as you had to mount it higher that you probably wanted to, would you go with the horizontal slits if you had to do it again?
    *NEW Addition: Misano Red RS4
    01.5 S4
    For sale(pm me for details):
    FRONT AIRBAGS !CHEAP!
    Stock S4 swaybar
    "I'd have one of those... if I were the sort of person that looked at my sister and thought, mmm..." - Jeremy Clarkson about the Roush Mustang.
    Active Member Four Rings
    Dec 11 2006
    Boston
    looks great man!
    Stage 3+ RS6's
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Looks good man. If you move its back a few inches will it clear up enough room to drop it down more? Do you have any pics without the bumper on?
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Nov 02 2005
    S4
    VA
    Quote Originally Posted by RuS4ty View Post
    i've been working on repainting the grill but function > fashion right now ftw.
    and no, i like the vertical because "both" intercoolers are getting the same air flow .. i didn't want the ebay core because the top core is behind the bumper and i imagine it's not getting good airflow....
    when i move it back im gonna try to lower it some, but i might have to redo the bottom connections to the intercooler to move the pipes up a little so they won't bump into the bottom of the bumper..im just glad everything is working right for now.
    -Luis
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    nice work, funky look tho
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Veteran Member Four Rings McKennaS4's Avatar
    Sep 25 2006
    2500 dodge ram diesel
    Boston, MA
    Quote Originally Posted by lrg8683 View Post
    not hating but the same amount of your core is hidden by the bumper as is the ebay core. it doesnt make a difference "which intercooler" gets the cooler air because they all mix together at the throttle body before entering...... lets see some logs! =) clean install. but like others have said, it looks a bit too high. maybe it'd be better with an rs4 bumper?
    01 Casa sedan 6MT, sport, cold
    Nov 02 2005
    S4
    VA
    Quote Originally Posted by McKennaS4 View Post
    it's not the same amount covered .. the ebay one is covering an entire intercooler, only about 2.5 inches of the top of mine isbeing covered and when i can lower it it'll be a little less amount of "covered" intercooler.
    -Luis
    Mar 07 2007
    Belmont, MA
    id like to see how low you can mount it, i might go this route (treadstone) do you have installation pictures, and what pipe kit you used?
    and which core did you go with? i was looking through treadstone's website and could only find 2-1 intercoolers.
    ThorTechnik.com
    Nov 02 2005
    S4
    VA
    i bought josh's s4tt's old piping kit.. and all i'd say is to get endtanks that are smaller.. thats the reason mine is mounted high.. the sides if the entanks go so far down that they push the bumper. if i mount it too low.
    -Luis
    Nov 02 2005
    S4
    VA
    this is what it looked like when i mounted it lower.. but you can see that it deforms the bumper at the bottom.. my laptop recently died so i lost all the pics of the mounting and plumbing
    -Luis
