Results 1 to 8 of 8
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Cool need to remove bumper to replace xenon bulb?
    question- does anyone know for certain that you have to remove the front bumper of an a4 sline in order to replace a xenon bulb? one dealer said that they had to remove it and another said that they didnt have to. id there any way a dealer could replace the bulb without the bumper removal? im short on time i just need to get my stories straight before i ask about it. thanks
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Sep 15 2005
    Norwalk, CA
    Re: need to remove bumper to replace xenon bulb?
    it depends on the size of the hand and willingness to get scratched up. It is POSSIBLE to change bulb without removing bumper, but it's not that easy and won't be completely painless.
    Peter
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
    Registered Member Three Rings era's Avatar
    Feb 01 2008
    2008 A4 2.0T Quattro TIP
    Brooklyn NYC
    Why dont you try Ray, I bet you cant change it that way.
    RedS-Line, I think it would be A LOT easier to just take off the bumper and do it.
    - Debadged - Blacked-out RS4 Grille - Prolumen 6000k HID - Llumar 35%/15% - Höen Fogs - CC Mod - VAG'd - Gun Smoked Tails -
    - Blacked-out Housing - VAG'd - CF DTM Style Spoiler - Painted Red Calipers - Red Interior LEDs - Stasis SS CO - Angel eyes -
    About to install:
    Feb 03 2008
    Brooklyn, NY
    Well era why don't you let me try on your car then cause obviously I don't have S-Line or S-Line exterior!
    Ray
    Sep 15 2005
    Norwalk, CA
    that works for both s-line and non s-line. I did that for my halogen non-sline. It works, but it was VERY painful, needing to push things aside while my arms get scratched up squeezing in there trying to fit the bulb.
    Again, it can be done, but I wouldn't recommend it to anyone after I have given it a try.
    Peter
    Registered Member Two Rings
    May 15 2008
    Miami, FL
    you don't have to totally remove to bumper to change the headlight. just whatever side your going to replace. pull out the fender lining and removed the 10mm nuts that hold the bumper on and then the torx screws on the top. then just pull the bumper out a bit and you can removed the headlamp and change the bulb. if you need more/better instructions let me know cause i'm a tech.
    Mar 19 2008
    thanks for the info guys, especially from jbish. did not know it was possible without bumper removal. time to let the tread die now...........
    2019 S5 BO.SS
    2009 R8 6 Volt :)
