Results 1 to 3 of 3
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Question Flywheel dimensions?
    Anyone know the dimensions of the stock flywheel by chance? I know they weigh like 28 pounds or something, but what is the diameter and thickness? Thanks!
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Feb 17 2004
    Sterling, VA
    Re: Flywheel dimensions?
    I'm not sure of the thickness but, I know that the friction surface that the clutch disc sits on is 240mm diameter. Not sure if that helps or not.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Feb 19 2007
    La Crescent, MN
    Thanks for the reply Daft, I kind of found out anyway. The reason I am asking is becuase I have to send my flywheel into VAST to get resurfaced. I went over to the shop that was getting my flywheel out after work today and I was able to measure it and luckily it fits into one of those USPS Priority Flat Rate boxes! lol They are like 12x12x6 and can be as heavy as you need and its only 12 bucks! STOKED! Anything else would have been WAY more expensive! Thanks for the help though!
