Results 1 to 12 of 12
    Veteran Member Three Rings onewicked's Avatar
    Sep 25 2007
    2001 A6 2.7t
    Dirty Jersey
    What spark plugs should i get for my 01 2.7t
    I want to change my plugs in my 2001 a6 2.7t. What do you guys use/recommend?
    2001 Audi A6 2.7t
    THE C5 UNION
    Past cars:
    1998 BMW 528i Sport
    1995 Eagle talon TSI w/ 6bolt swap(for sale)
    1996 VW jetta VR6
    1998 VW jetta 2.0 Turbo
    AMS AUTOWERKS #1
    Senior Member Three Rings Chopstixs's Avatar
    Jan 22 2008
    2.8 Single Turboed A6/2011 Tahoe
    Va
    Re: What spark plugs should i get for my 01 2.7t
    X2
    Through out the years, People have used "Chopstix" to eat rice.........I do the same.
    C5 UNION MEMBER
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    stock plugs always work good
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Sep 25 2007
    Nashville, TN
    i went with NGK Iridiums. They are extremely good but a little more expensive then stock.
    Feb 17 2004
    Sterling, VA
    The stock plugs are the NGK PFR6Q. They retail for about $11ea.
    If you are stock thru Stage 2, the stock ones will do the job since the OEM coilpacks are fairly powerful. I tried plain old copper plugs at a smaller gap on mine when I was stage 1 and it really didn't do anything for me at all. In fact, the smaller gap reduced throttle response a tad.
    The stock gap is just fine with our coils.
    When I moved to Stage 3 fueling and software, I changed to the Bosch Platin F5DP0R. ($16ea.) This is a very high performance platinum plug with a very thick center electrode compared to the plain old Bosch platinums that the parts stores sell. The F5DP0R is two heat ranges cooler than stock (stock would be a 7 instead of a 5). The reduction in heat range reduces cylinder pressure (increase in temperature = increase in pressure) and also draws more of the heat into the cylinder head for dissapation via the cooling system.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Senior Member Two Rings a62.7t4ceo's Avatar
    Mar 16 2007
    Stock is totally fine.
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    I just upgraded from Iridiums to the Bosch Platinum Side Fires. Much better, much smoother, and solved the intermittent ignition timing I was having. I am also running K04s @ 23psi...
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
    Nov 19 2005
    Pair of (. )( .)
    Bosch Platinum 2 contact , work so much better then stock, will go for 4 contact soon :)
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Apr 18 2007
    ny
    Denso Iridiums, car runs beautiful, very smooth.
    Nov 20 2005
    you can order some on purems.com they have a couple that were mentioned
    i get all my stuff there!
    is it 4:20 yet?
    Sep 25 2007
    2001 A6 2.7t
    Dirty Jersey
    Thanks guys
    2001 Audi A6 2.7t
    THE C5 UNION
    Past cars:
    1998 BMW 528i Sport
    1996 VW jetta VR6
    AMS AUTOWERKS #1
    Active Member Four Rings Ben@SpeedBarn's Avatar
    03 A6 2.7t, 00 GTI, 76 GMC
    Pittsburgh, PA
    Yeah I ran stock NGK PFR6Q in my 01 S4. Dealer put them in at 40k, and I changed them out at 80k. They still looked brand new, and it was chipped the entire time. Just picked up my 03 A6, with 39k, so I will be putting the same plugs in there very soon.
