Okay, so my window acted up a long time ago, assumed it was the regulator. Well I have it pulled apart now, and the cable is torn up and binded ect.. I have a new cable/regulator. Also have the Green wheel that the cable wraps around. I am stuck though, How do I put the cable on that green wheel that the motor spins? it seams like how ever I try to put it on the cable is loose and ends up binding again when I try and move the window. How do I wrap the cable around that? Am I doing something completely wrong? I figured the new cable could just be simply wrapped around the green piece put back in to that spot and that was it.
Is there a trick?
