Results 1 to 19 of 19
    Veteran Member Four Rings YZracer's Avatar
    Sep 20 2005
    Scottsdale, AZ
    Weird noise from wheel
    My front right (passenger) wheel is making a weird noise. When I start driving, it makes this on and off clicking noise. It is like a card stuck in bicycle tire spokes except in a deeper tone and slightly longer. When I put the car up on the lift and spin the wheel it makes the same clicking noise just a lot quieter (I am assuming from lack of weight and pressure on the wheel).
    Is this a bad wheel bearing? I had a bad bearing in the rear before but that sounded different. Is this still a bad bearing I guess with just different damage?
    CURRENT TOY
    2013 TT-RS Ibis White - Stock for now......
    Sold:
    2010 B8 S4 Phantom Black: Stasis Touring Suspension Kit, APR Pulley, APR 93 Octane Pulley Tune, APR Full Carbonio Intake
    Parted and Torn down:
    2000 Black 6spd S4
    SSP Tuned PJK04 Stage 3
    Burned:
    2000 S4 Tiptronic (B5)
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    Re: Weird noise from wheel
    could also be a failing ball joint on one of the control arms or failing cv joint
    My car is fast
    Dec 06 2007
    Calgary, AB, Canada
    The ABS sensor and track comes to mind...
    Sep 20 2005
    Scottsdale, AZ
    ^^^What do you mean exactly? I don't fully understand. How can the ABS sensor be an issue when the car is off and I am just spinning the wheel? Also, what is Track? I haven't heard this term before.
    CURRENT TOY
    Sold:
    2000 Black 6spd S4
    Burned:
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    could be your brake setup...
    Veteran Member Three Rings tbone5446's Avatar
    Nov 16 2006
    b5s4, 85 4runner T3/T4 turboed
    San Diego
    unbelievable, my wife called me this afternoon to tell me the EXACT same thing was happening with our S.
    I only drove it for a half mile or so to hear it before dinner and that is why I came on here to see if anyone else might know what it was.
    It does sound like a wheel bearing issue to me but then again I haven't had a chance to really check it out.
    After dinner she did have to drive it home on the Interstate and said the noise would speed up and slow down with the car.
    So tomorrow I will take a look at it.
    If you figure it out I would love to hear what it was.
    edit:after making this post she told me that this morning she heard a thud, pop, or clunk she can't remember exactly which, so.......
    when I drove the car for 2 minutes it drove fine and I could only hear the noise on deceleration.
    to me I would say it sounded like a card in spokes but almost birdlike if that makes any sense
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    CV Joint
    Jul 21 2005
    Bedford/MA
    undoubtedly a constant velocity joint if the sound speeds up with tire rpm
    My car is fast
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    Quote Originally Posted by IamEzraM View Post
    Then its a wheel bearing most likely
    Veteran Member Three Rings Justin:NorCal's Avatar
    Feb 08 2008
    2000 Audi S4 (new build), 2000 Audi S4 Stage 3 (stolen last year)
    Dublin, CA
    Look inside the wheel and wheel well to see if there is grease ;) If you blew the cv boot your joint is going to start clicking.
    2000 Audi S4 Silver (stock) < new build
    2000 Audi S4 Stage 3 Black (Tip) < stolen last year
    Nov 16 2006
    San Diego
    I jacked my car up last night and checked all boots, no tears whatsoever
    no play in the wheels either so I am assuming it isn't a bearing
    However my wife did take the car to work again today and I called to see if it had gotten worse, she said it made absolutely no noise today.
    Hmmmmmm....so I guess this weekend I will tear into it and see if something is amiss.
    Any other ideas?
    Sep 20 2005
    Scottsdale, AZ
    I checked my car as well. No tears or rips or leaks. Still making the noise though. I can't hear it above say 15mph, but below that it is there. So what do you guys think it is?
    CURRENT TOY
    Sold:
    2000 Black 6spd S4
    Burned:
    Jan 11 2007
    Salt Lake City, Utah
    Quote Originally Posted by YZracer View Post
    Sames here. Was just about to post on it. I can only hear mine from a stop til like 15 MPH. Pretty sure CV boots are good cause they were when I checked them less than 1k mi ago.
    Nov 16 2006
    San Diego
    wow so 3 of us are experiencing the same thing, but no one knows what it might be.
    I am starting to think it is something inside the differential but I really want to be wrong.
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    I put my vote in for a CV joint since when they start to go they make a clicking noise like you described. A bad wheel bearing makes more of a steady rubbing or pulsing noise. Does it get better or worse when you turn?
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Established Member Two Rings Hoxmarch's Avatar
    Oct 22 2008
    01 Nogaro S4 6mt <3
    Houston
    Bump from the dead for the same problem. Just started happening about 2 or 3 days ago...
    CV Joint? How do I fix that? :\
    Registered Member Two Rings
    May 07 2008
    98' Jetta GLX, 68' Coronet
    Dalton Oh,
    I'm voting CV joint as well. My Jetta has had both of its CV joints do that and the boots haven't ripped. Granted we're talking about a Audi and not a VW but from my experience it sounds like a CV joint.
    May 07 2008
    Dalton Oh,
    What I did was just buy whole new axles with both the inner and outer CV's on it. I don't know how it goes for Audi's but buying a new axle means not having to worry about repacking the joints.
    Apr 13 2008
    Playa Del Rey, CA
    I have also been having the same issue for about 4 months now. the noise hasnt gotten any worse. I cant hear it with the windows up and it is strictly wheel rpm dependent (aka not engine speed). mine almost sounds a little more like if air is being let out mixed in with a squeeking. I cant put my finger on the cause of the noise either, its the front left (driver) wheel. i replaced the wheel with the spare to make sure it wasnt a rock stuck in the tread or something, still the same noise. with the car jacked up there is still a noise but different sound due to the wheel not being loaded. the noise is definitely once every revolution..... hopefully someone knows the answer to this.
