Results 1 to 40 of 63
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    02 sensor affecting instant MPG readings?
    Does the 02 sensor have any effects on the instant MPG display or does that work strictly of the inj. pulses. When driving my car the instant MPG will vary some but will always end up reading 5 MPG, even if I'm cruising at 40MPH and in 5th gear. I think I might have a lazy 02 as I only get about 200 miles to a tank no matter how I drive it and my buddy said I had flames coming out the back so it's obviously rich.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Registered Member Three Rings SlappyB6's Avatar
    May 14 2008
    W-S, NC
    Re: 02 sensor affecting instant MPG readings?
    Sounds like a definite possibility. And yeah, it definitely sounds like you're running rich. I would pull out the O2 sensors and see if there's any build up on them. Try cleaning them first and see if that makes a difference.
    And 200 milles to a tank? Wow, maybe I'll go for show instead of go. I have 340 on my current tank, and it's still at 1/4.
    02 A4 - 5spd - Sport - VM DP
    Capt. Obvious - "Not me. I fart rainbows, shit rose pedals and piss excellence."
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    200 miles is pretty bad. I'm even getting 300 with the 550's. I have an extra primary 02 sensor you can try and ship back to me.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by CO AVANT View Post
    Wow. I've pushed close to 400miles on a tank with 630s . Granted it was highway cruising but still..
    -Doug
    Feb 12 2004
    Everywhere
    I have a little of what we call "a lead foot" I really need a 6spd out here for obvious high speed reasons. Too many open roads to haul ass on. If anyone finds a B6S4 tranny let me know ;)
    Dec 03 2005
    2 pedals 1FG
    connecticut
    We should find you a 2.8L 5spd.
    -Doug
    Feb 12 2004
    Everywhere
    6spd FTW. I want to be at 4000rpms in 6th gear at 100mph. I do not think the 2.8 gearing can get me there. What is clint seeing? I'm sucking gas down like crazy without better high end gearing in there.
    Chris I can send this 02 sensor out to you today so you can try it out and send back. Just need to pay for shipping. No need buying one if that's not the problem. They are pricey.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    When I drove Clint's car: 70mph in 5th gear was 3,000rpm. I wanted to go faster but was hesitant due to Memorial Day weekend and being on a back road in NJ (if there is such a thing)
    I think it'll be near, or slightly over, 4,000rpm at 100mph. I'll let you know (first hand) later this summer since my car will have the 2.8 trans in it.
    -Doug
    Feb 12 2004
    Everywhere
    let me know what it is at 150mph too please.
    Too bad you can't do that out there. I have never done that. I never speed.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I have to make a few phone calls in order do to that around here.
    Otherwise I'll have to wait until I come out there. Ever go to the Salt Flats? I think that would be a cool trip with the AVants.
    -Doug
    Feb 12 2004
    Everywhere
    Roads, where we're going we don't need no stinking roads...
    Salt flats would be fun....but I like to stay out of Utah as much as possible lol. No offense Sean There are a lot of paved roads with no one on them out here. And you can see for MILES
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    damn you Jordan!
    right when i click on the thread too
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    Quote Originally Posted by dirtybrd View Post
    I have the exact same problem and it is killing me ...Is it the 1st one or the secondary?
    Feb 12 2004
    Everywhere
    primary, 1st one
    Feb 12 2004
    Everywhere
    Quote Originally Posted by sean1.8t View Post
    damn you Jordan!
    Sorry buddy.
    Mar 21 2006
    Lakeland, FL.
    Jordan, you have PM.
    I'm back bitches!
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Bad O2 sensor will cause it to run rich as fuck...almost to the point of misfires.
    What are your A/F readings?
    There is a test you can do to test the O2 sensor to see if it is performing properly. I do not have the specifics because I am in Texas right now and my Bentley is on my laptop at home. Basically you remove it from the testpipe/cat and measure the voltage going across it with a multimeter in free air.
    Most likley the DTC that is associated with it has been disabled so you will have to revert back to good old American troubleshooting.
    Pull your plugs and see if they are wet...only do it with the motor lukewarm or cold though...no need to ruin a head.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    It would only be the primary...all the secondary does is report catalyst efficiency...
    Dec 03 2005
    2 pedals 1FG
    connecticut
    In that case, I'm going to get myself a Mr. Fusion for the AVant.
    Should hit 400awhp then!
    -Doug
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Instead of doing the worthless 2.8 mod, would I can see about having few taller 5th (and 5th + 6th) gearsets brought over...
    Same final result of lower cruising RPM without the shitty midrange gearing.
    Sep 17 2006
    SLC, UT
    how about a dogbox 6 speed w/ 1-4 gears strait cut. and 5th and 6th oem and taller?
    i'd be willing to pay, oh, i dunno.... $800 for that..
    sound good?
    Current:
    Previous:
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I can do that but it would cost $15K to rent for one season, $60K to buy outright (Kraftwerk Transmission)
    Of course it would have sequential shifting too. :)
    Sep 17 2006
    SLC, UT
    alright, you're good at this...
    $900! and not a penny higher
    Current:
    Previous:
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by 400HPA4 View Post
    Remember we were talking over AIM about misfires I was having, I tried plugs, coils, CTS and harness. It went away about 90% after I put the cams in, thus leaning it out.
    I'm back bitches!
    Mar 21 2006
    Lakeland, FL.
    I tried another 02 sensor ,not yours Jordan, but I did receive it and will try it also. Nothing changed. Still reading 5 MPG, still getting small misfires when transitioning from off to on boost, and first start up in the morning. It still stalls (5 times on the way to lunch) and won't start when the engine is hot without giving it some throttle. I need help. I've been thinking of switching back to NGK 7s instead of the FR5DTC I'm running. Or drilling a hole in the throttle plate to lean it out @ idle.
    I'm back bitches!
    May 14 2008
    W-S, NC
    Have you checked to make sure none of your vacuum lines or intake/lines are clogged, leaking or cracked? And did you check for correct gapping on the plugs? (I'm sure you did). Just throwing out ideas. Clogged injectors?
    Mar 21 2006
    Lakeland, FL.
    Everything appears to be fine, FR5DTC can't be gapped.
    I'm back bitches!
    May 14 2008
    W-S, NC
    I'm gonna guess something electrical then. Bad ground or sensor?
    Mar 21 2006
    Lakeland, FL.
    Anyone else?
    I'm back bitches!
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    sound good?
    The sound of straight cut gears......
    -Sami-
    Feb 12 2004
    Everywhere
    What about trying to plug a random maf back in? What about testing the voltage of the 02 sensor plug with a voltometer?
    Mar 21 2006
    Lakeland, FL.
    I removed my MAF connector. I never had any issues until the turbo blew and I sent my ECU out for the 8500 file. I really think there is an issue with my flash. I just changed my plugs back to NGK 7s to see if they help.
    I'm back bitches!
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    Heh, CO Avant or Greg
    Do you know the procedure for checking the front O2 sensor or what readings to check for with the Voltometer?
    I'd like to see if mine is working before i bite the bullet and replace it (I've had some issues that I think my be related to the O2. Just looking for a waty to test it since I don't have acess to VAG COM)>
    Thanks,
    Jesse
    Feb 12 2004
    Everywhere
    you could always have Dirtybrd (Chris) send you the one I sent him and try it out. Then send it back to me. I forgot the specs on the 02 sensor plug voltage. I'll try to find it. PM diagnosticator, he might know off the top of his head...
    Mar 21 2006
    Lakeland, FL.
    I did a little Vagging today.
    @ idle channel 001 -28.1 and in boost 20
    @ idle channel 031 .930 and in boost 1.991
    What do you guys think? I only have 3 sensors that regulate fuel, 02, CTS, and MAP. I tried another 02, no change. My CTS and the connector are new and soldered in. So I thought my MAP sensor might be reading boost all the time but it was 1000 mbar and 1010 mbar at idle. I'm lost. I guess I need to do some old fashion diag. I have two small pre-turbo exh. leaks but I don't think it would affect it that much plus it's been like this before the leak started. Today I filled up 15.5 gallons and got 188 miles to the last tank. That's just under 12 MPG.
    I'm back bitches!
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Call me Chris, you are running rich as fuck...surprised the plugs are not fouled. I ran into this situation with a GTRS on a 337 that I installed, it was seeing the same O2 readings and was the primary O2 sensor that was bad.
    Mar 21 2006
    Lakeland, FL.
    I got a primary 02 out of used car from work, it had about 60k on it but it might be bad also. Jordan did send me a spare 02 he had and told me that he got the same values from it as a new one. I guess I'll try that one to see if it helps, if not I'll call you, I still have your number.
    I'm back bitches!
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Don't even waste you time taking readings...put the new sensor in and replace the plugs. Everything should be A-OK. May take a bit for the ECM to adapt.
    Mar 21 2006
    Lakeland, FL.
    I'll do it tomorrow. I just didn't want to spend $130 on a new 02 without being sure. I just hope it works, in the morning it sounds like a bridge ported rotary, rut, rut, rut and the stalling is rediculous. It always happens with people in the car, and they ask how I can have almost 10k in a motor and it stalls. Very sucky!
    I'm back bitches!
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    yah i replaced my old o2 sensor and guess what no trim changes.
    waste of $160 (too much i know).
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
